Date/Time: Sun, 09 Mar 2025 12:45:42 +0000
switching from CQG / AMP to Teton Order Routing
View Count: 1688
[2022-01-08 06:40:11] |
User340810 - Posts: 9 |
I was curious to know how I could switch from my current setup to one where I would use Teton. Do I just need to open an account with the brokers / clearing firms mentioned in the instructions and change my data/trade service settings to SC/TT Futures Order routing? Also, is there more information on commissions / fees for TT? |
[2022-01-08 23:52:32] |
What you want to use is the Teton Order Routing service. This is not involved with TT at all. You do need to change to a broker listed in step 2 here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-24 13:08:42] |
User468762 - Posts: 19 |
On the page it lists AmpFutures (clearing firm. Expected upcoming support). So if I want to stick with AmpFutures and keep Sierra chart, I would have to wait for Amp to be 100% on board, right?
[2022-01-24 14:17:58] |
Yes. But we have no idea when that would be. You could be waiting a long time.
[2022-03-06 05:26:54] |
User630795 - Posts: 92 |
AMP is saying that they want to see over 1,000 accounts on Teton. How many do you currently have using Teton? If it is over 1,000 users, you should let AMP know.
