Date/Time: Tue, 26 Nov 2024 04:51:44 +0000
problem with automated spreadsheet execution of multiple contract entries with attached targets
View Count: 1235
[2014-04-08 08:57:03]
enemyspy - Posts: 306
spreadsheet entry keeps creating target mismatch upon a signal being triggered with attached orders.
-If position size is set to 1 with a target and stop triggered it works
-If position size is set to any thing > 1 on the order window with the matching targets when a trade signal is generated the window keeps resetting the selection back to 1 which creates a target mismatch and does not enter the order.
-if spreadsheet trading is disabled and position is entered manually the order executes correctly with no target mismatch.
Spreadsheet settings:
Max position size: 100
Support multiple entries in same direction: True
Scale in/scale out in oe window= Not enabled
what could be causing this to happen?
[2014-04-08 09:12:42]
We are testing this now.
[2014-04-08 09:26:54]
We enabled Use Attached Orders on the Trade Window for the chart that has the Spreadsheet System for Trading study. There is a single Target and Stop order defined on the Trade Window.
We triggered an order from the spreadsheet and J26 was set to 0. The order quantity was 1 and so was the Attached Orders.
We set J26 to 2 and triggered another order, and the order quantity was 2 and the Target and Stop orders were also set to 2.
Therefore, we do not see a problem.
What is your Attached Order configuration?
[2014-04-08 09:28:08]
Actually, we think we see where you are going wrong. The order quantity must be specified from cell J26. It cannot be specified from the Trade Window. The documentation does indicate this.
[2014-04-08 17:56:28]
ok. Thanks knew I was going wrong somewhere. Overlooked this as previous experiments only used 1 contract.
