Date/Time: Wed, 05 Mar 2025 04:22:58 +0000
blank charts
View Count: 610
[2022-01-07 17:21:44] |
User93731 - Posts: 83 |
Dear Support: I have two blank Charts (one is for TSLA and the other of for AMZN, both stock symbol) and I use your (SC Data_All services datafeed) with my sim account. I went to your document of 3.4.1, which is asked to check “Current Quote Window”, and there is not movement on the last price and last size and went to 3.4.2 , which is asked to check and add symbol to the new quite board and the last price and last Size are zero within hours that the stock market opened. In addition, there is no a thing shown at my Quote board, so I do not think it is a problem of Symbol limits.. It said I should contact you for this issue after all these fixs are not working . In addition, I have found the following problem: (at Chart-setting, Main settings, Data Range in File (yyyy-mm-dd), I cannot fill in any date there in “From date”. Even after I fill a data, hit Apply and OK, then chart is still not updating and when I go back to this chart setting again and this from date is still empty. It does not allow a date. I am instructor at university and I have asked my computer to install SC in November last year and I used my login to fist login in the computer lab to this lab .. SC works well for my personal laptop and have not problem. So I though you might want to have this information as background to solve this problem. Many thanks and looking forward to your reply. hiwhited |
[2022-01-07 18:52:28] |
John - SC Support - Posts: 38380 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-07 19:21:07] |
(1) For your request to clear the message log, it does not allow the completely gone. The above is what left after I ask to clear ALL lines: Software version: 2333 64-bit | 2022-01-07 19:05:20.915 Primary Thread ID: 8064 | 2022-01-07 19:05:20.915 Usage end date: 2022-05-03 | 2022-01-07 19:05:20.915 Enabled for: Sierra Chart Historical Data Service. | 2022-01-07 19:05:20.915 Enabled for: Delayed Denali Exchange Data Feed. | 2022-01-07 19:05:20.915 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-01-07 19:05:20.915 Current selected Data/Trading service: SC Data - All Services | 2022-01-07 19:05:20.915 Custom symbol settings values: enabled | 2022-01-07 19:05:20.915 Chart Update Interval: 500 | 2022-01-07 19:05:20.915 Intraday Data Storage Time Unit: 1 | 2022-01-07 19:05:20.915 Time Zone: +00:00:00 (UTC+00) | 2022-01-07 19:05:20.915 2022-01-07 19:05:20 Local computer time in UTC | 2022-01-07 19:05:20.915 2022-01-07 19:05:20 Local computer time in SC Time Zone | 2022-01-07 19:05:20.915 2022-01-07 17:26:40 Server time in UTC | 2022-01-07 19:05:20.915 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-01-07 19:05:20.915 Program path: C:\SierraChart\ | 2022-01-07 19:05:20.915 Data Files path: C:\SierraChart\Data\ | 2022-01-07 19:05:20.915 OS Version Number: 10.0 | 2022-01-07 19:05:20.915 Locale Setting: C | 2022-01-07 19:05:20.915 Allowed protected custom studies: | 2022-01-07 19:05:20.915 (2) TSLA (3) The new message log Starting from TSLA shows up below: Software version: 2333 64-bit | 2022-01-07 19:05:20.915 Primary Thread ID: 8064 | 2022-01-07 19:05:20.915 Usage end date: 2022-05-03 | 2022-01-07 19:05:20.915 Enabled for: Sierra Chart Historical Data Service. | 2022-01-07 19:05:20.915 Enabled for: Delayed Denali Exchange Data Feed. | 2022-01-07 19:05:20.915 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-01-07 19:05:20.915 Current selected Data/Trading service: SC Data - All Services | 2022-01-07 19:05:20.915 Custom symbol settings values: enabled | 2022-01-07 19:05:20.915 Chart Update Interval: 500 | 2022-01-07 19:05:20.915 Intraday Data Storage Time Unit: 1 | 2022-01-07 19:05:20.915 Time Zone: +00:00:00 (UTC+00) | 2022-01-07 19:05:20.915 2022-01-07 19:05:20 Local computer time in UTC | 2022-01-07 19:05:20.915 2022-01-07 19:05:20 Local computer time in SC Time Zone | 2022-01-07 19:05:20.915 2022-01-07 17:26:40 Server time in UTC | 2022-01-07 19:05:20.915 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-01-07 19:05:20.915 Program path: C:\SierraChart\ | 2022-01-07 19:05:20.915 Data Files path: C:\SierraChart\Data\ | 2022-01-07 19:05:20.915 OS Version Number: 10.0 | 2022-01-07 19:05:20.915 Locale Setting: C | 2022-01-07 19:05:20.915 Allowed protected custom studies: | 2022-01-07 19:05:20.915 NEW Message start from below TSLA 1 Min #1 | Reloading chart. | 2022-01-07 19:12:31.467 TSLA 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TSLA.scid | 2022-01-07 19:12:31.475 TSLA 10 Min #1 | Reloading chart. | 2022-01-07 19:13:16.823 TSLA 10 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TSLA.scid | 2022-01-07 19:13:16.881 File >> Disconnect selected. | 2022-01-07 19:13:34.684 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-07 19:13:34.686 DTC Client socket (3) | CloseSocket call. | 2022-01-07 19:13:34.686 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-07 19:13:34.686 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-01-07 19:13:34.686 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-01-07 19:13:34.686 DTC Client socket (2) | CloseSocket call. | 2022-01-07 19:13:34.687 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-01-07 19:13:34.687 SC Data - All Services | Disconnected. | 2022-01-07 19:13:34.687 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-01-07 19:13:34.687 SC Data - All Services | Connected to server complete. | 2022-01-07 19:13:41.667 Triggering next historical data download in queue. | 2022-01-07 19:13:41.668 Triggering next historical data download in queue. | 2022-01-07 19:13:41.668 Triggering next historical data download in queue. | 2022-01-07 19:13:41.668 Triggering next historical data download in queue. | 2022-01-07 19:13:41.668 No download requests in the queue to start downloads for. | 2022-01-07 19:13:41.670 No download requests in the queue to start downloads for. | 2022-01-07 19:13:41.670 No download requests in the queue to start downloads for. | 2022-01-07 19:13:41.670 No download requests in the queue to start downloads for. | 2022-01-07 19:13:41.670 SC Data - All Services | Starting real-time market data updates for: TSLA. ID: 1 Service code: equities.us | 2022-01-07 19:13:41.724 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: TSLA | 2022-01-07 19:13:41.724 SC Data - All Services | Requesting security definition data for: TSLA. ID: 1 | 2022-01-07 19:13:41.724 Added historical Intraday data request for TSLA to the queue. | 2022-01-07 19:13:41.724 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2022-01-07 19:13:41.724 Triggering next historical data download in queue. | 2022-01-07 19:13:41.724 Delaying start of download for TSLA | 2022-01-07 19:13:41.724 SC Data - All Services | Starting real-time market data updates for: QQQ. ID: 2 Service code: equities.us | 2022-01-07 19:13:41.726 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: QQQ | 2022-01-07 19:13:41.726 SC Data - All Services | Requesting security definition data for: QQQ. ID: 2 | 2022-01-07 19:13:41.726 Added historical Intraday data request for QQQ to the queue. | 2022-01-07 19:13:41.726 Intraday data recording state for symbol QQQ is set to download 'Pending'. | 2022-01-07 19:13:41.726 Triggering next historical data download in queue. | 2022-01-07 19:13:41.726 Mapping CLG22-NYMEX to CLG22. Service code: nymex | 2022-01-07 19:13:41.726 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLG22-NYMEX (CLG22). ID: 3 Service code: nymex | 2022-01-07 19:13:41.726 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-01-07 19:13:41.726 SC DTC Delayed Exchange Data | Requesting security definition data for: CLG22-NYMEX (CLG22). ID: 3 | 2022-01-07 19:13:41.727 Added historical Intraday data request for CLG22-NYMEX to the queue. | 2022-01-07 19:13:41.727 Intraday data recording state for symbol CLG22-NYMEX is set to download 'Pending'. | 2022-01-07 19:13:41.727 Triggering next historical data download in queue. | 2022-01-07 19:13:41.727 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTH22-BMEX. ID: 4 Service code: bitmex | 2022-01-07 19:13:41.727 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 10048 | 2022-01-07 19:13:41.727 SC DTC Data with Market Depth | Requesting security definition data for: XBTH22-BMEX. ID: 4 | 2022-01-07 19:13:41.728 Added historical Intraday data request for XBTH22-BMEX to the queue. | 2022-01-07 19:13:41.728 Intraday data recording state for symbol XBTH22-BMEX is set to download 'Pending'. | 2022-01-07 19:13:41.728 Triggering next historical data download in queue. | 2022-01-07 19:13:41.728 SC Data - All Services | Starting real-time market data updates for: CME_NY-CL-CME_20130700_CLN3. ID: 5 | 2022-01-07 19:13:41.732 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: CME_NY-CL-CME_20130700_CLN3 | 2022-01-07 19:13:41.732 SC Data - All Services | Requesting security definition data for: CME_NY-CL-CME_20130700_CLN3. ID: 5 | 2022-01-07 19:13:41.732 No historical data client is currently set to download historical Intraday data for CME_NY-CL-CME_20130700_CLN3. | 2022-01-07 19:13:41.732 Real-time Intraday chart data file updates started for CME_NY-CL-CME_20130700_CLN3 | 2022-01-07 19:13:41.732 Opened cached Intraday file: C:\SierraChart\Data\CME_NY-CL-CME_20130700_CLN3.scid. Thread ID: 8064 | 2022-01-07 19:13:41.732 Intraday chart data file opened for CME_NY-CL-CME_20130700_CLN3 | 2022-01-07 19:13:41.732 SC Data - All Services | Starting real-time market data updates for: AMZN. ID: 6 Service code: equities.us | 2022-01-07 19:13:41.732 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: AMZN | 2022-01-07 19:13:41.732 SC Data - All Services | Requesting security definition data for: AMZN. ID: 6 | 2022-01-07 19:13:41.732 Added historical Intraday data request for AMZN to the queue. | 2022-01-07 19:13:41.732 Intraday data recording state for symbol AMZN is set to download 'Pending'. | 2022-01-07 19:13:41.732 Triggering next historical data download in queue. | 2022-01-07 19:13:41.732 SC Data - All Services | Starting real-time market data updates for: NGM4-NYMEX. ID: 7 | 2022-01-07 19:13:41.732 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NGM4-NYMEX | 2022-01-07 19:13:41.732 SC Data - All Services | Requesting security definition data for: NGM4-NYMEX. ID: 7 | 2022-01-07 19:13:41.732 No historical data client is currently set to download historical Intraday data for NGM4-NYMEX. | 2022-01-07 19:13:41.732 Real-time Intraday chart data file updates started for NGM4-NYMEX | 2022-01-07 19:13:41.732 Opened cached Intraday file: C:\SierraChart\Data\NGM4-NYMEX.scid. Thread ID: 8064 | 2022-01-07 19:13:41.732 Intraday chart data file opened for NGM4-NYMEX | 2022-01-07 19:13:41.732 Mapping BTCF22-CME to BTCF22. Service code: cme | 2022-01-07 19:13:41.733 SC DTC Delayed Exchange Data | Starting real-time market data updates for: BTCF22-CME (BTCF22). ID: 8 Service code: cme | 2022-01-07 19:13:41.733 SC DTC Delayed Exchange Data | Requesting security definition data for: BTCF22-CME (BTCF22). ID: 8 | 2022-01-07 19:13:41.733 Added historical Intraday data request for BTCF22-CME to the queue. | 2022-01-07 19:13:41.733 Intraday data recording state for symbol BTCF22-CME is set to download 'Pending'. | 2022-01-07 19:13:41.733 Triggering next historical data download in queue. | 2022-01-07 19:13:41.733 Mapping GCG22-COMEX to GCG22. Service code: comex | 2022-01-07 19:13:41.733 SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCG22-COMEX (GCG22). ID: 9 Service code: comex | 2022-01-07 19:13:41.733 SC DTC Delayed Exchange Data | Requesting security definition data for: GCG22-COMEX (GCG22). ID: 9 | 2022-01-07 19:13:41.733 Added historical Intraday data request for GCG22-COMEX to the queue. | 2022-01-07 19:13:41.733 Intraday data recording state for symbol GCG22-COMEX is set to download 'Pending'. | 2022-01-07 19:13:41.733 Triggering next historical data download in queue. | 2022-01-07 19:13:41.733 Mapping YMH22-CBOT to YMH22. Service code: cbot | 2022-01-07 19:13:41.734 SC DTC Delayed Exchange Data | Starting real-time market data updates for: YMH22-CBOT (YMH22). ID: 10 Service code: cbot | 2022-01-07 19:13:41.734 SC DTC Delayed Exchange Data | Requesting security definition data for: YMH22-CBOT (YMH22). ID: 10 | 2022-01-07 19:13:41.734 Added historical Intraday data request for YMH22-CBOT to the queue. | 2022-01-07 19:13:41.734 Intraday data recording state for symbol YMH22-CBOT is set to download 'Pending'. | 2022-01-07 19:13:41.734 Triggering next historical data download in queue. | 2022-01-07 19:13:41.734 Mapping 6EH22-CME to 6EH22. Service code: cme | 2022-01-07 19:13:41.734 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6EH22-CME (6EH22). ID: 11 Service code: cme | 2022-01-07 19:13:41.734 SC DTC Delayed Exchange Data | Requesting security definition data for: 6EH22-CME (6EH22). ID: 11 | 2022-01-07 19:13:41.734 Added historical Intraday data request for 6EH22-CME to the queue. | 2022-01-07 19:13:41.734 Intraday data recording state for symbol 6EH22-CME is set to download 'Pending'. | 2022-01-07 19:13:41.734 Triggering next historical data download in queue. | 2022-01-07 19:13:41.734 DTC Client socket (1) | Creating socket. | 2022-01-07 19:13:41.779 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-07 19:13:41.779 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2022-01-07 19:13:41.779 DTC Client socket (4) | Creating socket. | 2022-01-07 19:13:41.829 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-01-07 19:13:41.829 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-01-07 19:13:41.829 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-01-07 19:13:41.829 DTC Client socket (4) | Connecting to IP: 64.38.174.180. | 2022-01-07 19:13:41.829 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-07 19:13:41.829 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-07 19:13:41.864 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-07 19:13:41.864 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-07 19:13:41.864 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-01-07 19:13:41.893 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-01-07 19:13:41.893 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-07 19:13:41.922 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-07 19:13:41.922 SC DTC Delayed Exchange Data | Received logon response. | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Successfully connected. | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6EH22-CME -> 6EH22 | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: BTCF22-CME -> BTCF22 | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLG22-NYMEX -> CLG22 | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: GCG22-COMEX -> GCG22 | 2022-01-07 19:13:42.581 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: YMH22-CBOT -> YMH22 | 2022-01-07 19:13:42.581 SC DTC Data with Market Depth | Received logon response. | 2022-01-07 19:13:42.677 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-07 19:13:42.677 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-07 19:13:42.677 SC DTC Data with Market Depth | Successfully connected. | 2022-01-07 19:13:42.677 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-07 19:13:42.677 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTH22-BMEX | 2022-01-07 19:13:42.677 SC DTC Delayed Exchange Data | Received security definition for symbol 6EH22-CME | 2022-01-07 19:13:42.705 SC DTC Delayed Exchange Data | Received security definition for symbol BTCF22-CME | 2022-01-07 19:13:42.705 SC DTC Delayed Exchange Data | Received security definition for symbol CLG22-NYMEX | 2022-01-07 19:13:42.705 SC DTC Delayed Exchange Data | Received security definition for symbol GCG22-COMEX | 2022-01-07 19:13:42.705 SC DTC Delayed Exchange Data | Received security definition for symbol YMH22-CBOT | 2022-01-07 19:13:42.705 SC DTC Data with Market Depth | Received security definition for symbol XBTH22-BMEX | 2022-01-07 19:13:42.801 HD Request # 96 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-01-07 19:13:46.600 HD Request # 96 | Download start date-time: 2021-07-05 19:13:46.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:13:46.601 HD Request # 96 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2022-01-07 19:13:46.602 Socket (5) | Creating socket. | 2022-01-07 19:13:46.603 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:13:46.603 Socket (5) | Connecting to IP: 8.18.161.133. | 2022-01-07 19:13:46.603 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:13:48.653 * Socket (5) | CloseSocket call. | 2022-01-07 19:13:48.653 Socket (0) | CloseSocket call. | 2022-01-07 19:13:48.653 Socket (5) | Closed. | 2022-01-07 19:13:48.653 HD Request # 96 | Error downloading historical Intraday data for TSLA. The network socket has been closed. Retrying download. | 2022-01-07 19:13:48.653 Added historical Intraday data request for TSLA to the queue. | 2022-01-07 19:13:48.653 Triggering next historical data download in queue. | 2022-01-07 19:13:48.653 Historical data download thread signaled to stop. | 2022-01-07 19:13:48.653 HD Request # 96 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TSLA | 2022-01-07 19:13:48.653 HD Request # 96 | Completion time: 2s | 2022-01-07 19:13:48.654 HD Request # 97 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-01-07 19:13:48.654 HD Request # 97 | Download start date-time: 2021-07-05 19:13:48.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:13:48.655 HD Request # 97 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2022-01-07 19:13:48.655 Socket (5) | Creating socket. | 2022-01-07 19:13:48.656 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:13:48.656 Socket (5) | Connecting to IP: 8.18.161.135. | 2022-01-07 19:13:48.656 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:13:50.715 * Socket (5) | CloseSocket call. | 2022-01-07 19:13:50.715 Socket (0) | CloseSocket call. | 2022-01-07 19:13:50.715 Socket (5) | Closed. | 2022-01-07 19:13:50.715 HD Request # 97 | Error downloading historical Intraday data for TSLA. The network socket has been closed. Retrying download. | 2022-01-07 19:13:50.715 Added historical Intraday data request for TSLA to the queue. | 2022-01-07 19:13:50.715 Triggering next historical data download in queue. | 2022-01-07 19:13:50.715 Historical data download thread signaled to stop. | 2022-01-07 19:13:50.716 HD Request # 97 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TSLA | 2022-01-07 19:13:50.716 HD Request # 97 | Completion time: 2s | 2022-01-07 19:13:50.716 HD Request # 98 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-01-07 19:13:50.716 HD Request # 98 | Download start date-time: 2021-07-05 19:13:50.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:13:50.717 HD Request # 98 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2022-01-07 19:13:50.717 Socket (5) | Creating socket. | 2022-01-07 19:13:50.717 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:13:50.718 Socket (5) | Connecting to IP: 8.18.161.133. | 2022-01-07 19:13:50.718 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:13:52.770 * Socket (5) | CloseSocket call. | 2022-01-07 19:13:52.770 Socket (0) | CloseSocket call. | 2022-01-07 19:13:52.770 Socket (5) | Closed. | 2022-01-07 19:13:52.770 HD Request # 98 | Error downloading historical Intraday data for TSLA. The network socket has been closed. Retrying download. | 2022-01-07 19:13:52.770 Historical data download thread signaled to stop. | 2022-01-07 19:13:52.770 HD Request # 98 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TSLA | 2022-01-07 19:13:52.770 HD Request # 98 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-01-07 19:13:52.771 HD Request # 98 | Completion time: 2s | 2022-01-07 19:13:52.771 HD Request # 98 | Intraday data download complete for TSLA. Unique request ID: 68 | 2022-01-07 19:13:52.771 Removing historical data download ID 68. | 2022-01-07 19:13:52.771 Real-time Intraday chart data file updates started for TSLA | 2022-01-07 19:13:52.771 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 8064 | 2022-01-07 19:13:52.771 Intraday chart data file opened for TSLA | 2022-01-07 19:13:52.771 HD Request # 98 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:13:52.771 Triggering next historical data download in queue. | 2022-01-07 19:13:52.771 HD Request # 99 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: equities.us | 2022-01-07 19:13:52.772 HD Request # 99 | Download start date-time: 2021-07-05 19:13:52.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:13:52.772 HD Request # 99 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2022-01-07 19:13:52.772 Socket (5) | Creating socket. | 2022-01-07 19:13:52.772 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:13:52.772 Socket (5) | Connecting to IP: 8.18.161.135. | 2022-01-07 19:13:52.772 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:13:54.832 * Socket (5) | CloseSocket call. | 2022-01-07 19:13:54.832 Socket (0) | CloseSocket call. | 2022-01-07 19:13:54.832 Socket (5) | Closed. | 2022-01-07 19:13:54.832 HD Request # 99 | Error downloading historical Intraday data for QQQ. The network socket has been closed. Retrying download. | 2022-01-07 19:13:54.832 Added historical Intraday data request for QQQ to the queue. | 2022-01-07 19:13:54.832 Triggering next historical data download in queue. | 2022-01-07 19:13:54.832 Historical data download thread signaled to stop. | 2022-01-07 19:13:54.833 HD Request # 99 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for QQQ | 2022-01-07 19:13:54.833 HD Request # 99 | Completion time: 2s | 2022-01-07 19:13:54.833 HD Request # 100 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: equities.us | 2022-01-07 19:13:54.833 HD Request # 100 | Download start date-time: 2021-07-05 19:13:54.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:13:54.834 HD Request # 100 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2022-01-07 19:13:54.834 Socket (5) | Creating socket. | 2022-01-07 19:13:54.834 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:13:54.834 Socket (5) | Connecting to IP: 8.18.161.133. | 2022-01-07 19:13:54.834 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:13:56.894 * Socket (5) | CloseSocket call. | 2022-01-07 19:13:56.894 Socket (0) | CloseSocket call. | 2022-01-07 19:13:56.894 Socket (5) | Closed. | 2022-01-07 19:13:56.894 HD Request # 100 | Error downloading historical Intraday data for QQQ. The network socket has been closed. Retrying download. | 2022-01-07 19:13:56.894 Added historical Intraday data request for QQQ to the queue. | 2022-01-07 19:13:56.894 Triggering next historical data download in queue. | 2022-01-07 19:13:56.894 Historical data download thread signaled to stop. | 2022-01-07 19:13:56.894 HD Request # 100 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for QQQ | 2022-01-07 19:13:56.894 HD Request # 100 | Completion time: 2s | 2022-01-07 19:13:56.895 HD Request # 101 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: equities.us | 2022-01-07 19:13:56.895 HD Request # 101 | Download start date-time: 2021-07-05 19:13:56.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:13:56.896 HD Request # 101 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2022-01-07 19:13:56.896 Socket (5) | Creating socket. | 2022-01-07 19:13:56.896 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:13:56.897 Socket (5) | Connecting to IP: 8.18.161.135. | 2022-01-07 19:13:56.897 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:13:58.940 * Socket (5) | CloseSocket call. | 2022-01-07 19:13:58.940 Socket (0) | CloseSocket call. | 2022-01-07 19:13:58.940 Socket (5) | Closed. | 2022-01-07 19:13:58.940 HD Request # 101 | Error downloading historical Intraday data for QQQ. The network socket has been closed. Retrying download. | 2022-01-07 19:13:58.940 Historical data download thread signaled to stop. | 2022-01-07 19:13:58.940 HD Request # 101 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for QQQ | 2022-01-07 19:13:58.940 HD Request # 101 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-01-07 19:13:58.941 HD Request # 101 | Completion time: 2s | 2022-01-07 19:13:58.941 HD Request # 101 | Intraday data download complete for QQQ. Unique request ID: 69 | 2022-01-07 19:13:58.941 Removing historical data download ID 69. | 2022-01-07 19:13:58.941 Real-time Intraday chart data file updates started for QQQ | 2022-01-07 19:13:58.941 Opened cached Intraday file: C:\SierraChart\Data\QQQ.scid. Thread ID: 8064 | 2022-01-07 19:13:58.942 Intraday chart data file opened for QQQ | 2022-01-07 19:13:58.942 HD Request # 101 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:13:58.942 Triggering next historical data download in queue. | 2022-01-07 19:13:58.942 HD Request # 102 | Downloading Intraday chart data for CLG22-NYMEX to the file CLG22-NYMEX.scid. Service: nymex | 2022-01-07 19:13:58.942 HD Request # 102 | Download start date-time: 2022-01-07 19:03:22.000000. File last date-time: 2022-01-07 19:03:22.000000 | 2022-01-07 19:13:58.943 HD Request # 102 | Using server: ds21.sierracharts.com port 10150 | 2022-01-07 19:13:58.943 Socket (5) | Creating socket. | 2022-01-07 19:13:58.944 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:13:58.944 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:13:58.944 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:00.986 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:00.986 Socket (0) | CloseSocket call. | 2022-01-07 19:14:00.986 Socket (5) | Closed. | 2022-01-07 19:14:00.986 HD Request # 102 | Error downloading historical Intraday data for CLG22-NYMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:00.986 Added historical Intraday data request for CLG22-NYMEX to the queue. | 2022-01-07 19:14:00.986 Triggering next historical data download in queue. | 2022-01-07 19:14:00.986 Historical data download thread signaled to stop. | 2022-01-07 19:14:00.986 HD Request # 102 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for CLG22-NYMEX | 2022-01-07 19:14:00.987 HD Request # 102 | Completion time: 2s | 2022-01-07 19:14:00.987 HD Request # 103 | Downloading Intraday chart data for CLG22-NYMEX to the file CLG22-NYMEX.scid. Service: nymex | 2022-01-07 19:14:00.987 HD Request # 103 | Download start date-time: 2022-01-07 19:03:22.000000. File last date-time: 2022-01-07 19:03:22.000000 | 2022-01-07 19:14:00.988 HD Request # 103 | Using server: ds23.sierracharts.com port 10149 | 2022-01-07 19:14:00.988 Socket (5) | Creating socket. | 2022-01-07 19:14:00.989 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:00.989 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-07 19:14:00.989 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:03.026 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:03.027 Socket (0) | CloseSocket call. | 2022-01-07 19:14:03.027 Socket (5) | Closed. | 2022-01-07 19:14:03.027 HD Request # 103 | Error downloading historical Intraday data for CLG22-NYMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:03.027 Added historical Intraday data request for CLG22-NYMEX to the queue. | 2022-01-07 19:14:03.027 Triggering next historical data download in queue. | 2022-01-07 19:14:03.027 Historical data download thread signaled to stop. | 2022-01-07 19:14:03.027 HD Request # 103 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for CLG22-NYMEX | 2022-01-07 19:14:03.027 HD Request # 103 | Completion time: 3s | 2022-01-07 19:14:03.027 HD Request # 104 | Downloading Intraday chart data for CLG22-NYMEX to the file CLG22-NYMEX.scid. Service: nymex | 2022-01-07 19:14:03.027 HD Request # 104 | Download start date-time: 2022-01-07 19:03:22.000000. File last date-time: 2022-01-07 19:03:22.000000 | 2022-01-07 19:14:03.027 HD Request # 104 | Using server: ds21.sierracharts.com port 10150 | 2022-01-07 19:14:03.027 Socket (5) | Creating socket. | 2022-01-07 19:14:03.027 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:03.027 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:14:03.027 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:05.073 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:05.073 Socket (0) | CloseSocket call. | 2022-01-07 19:14:05.073 Socket (5) | Closed. | 2022-01-07 19:14:05.073 HD Request # 104 | Error downloading historical Intraday data for CLG22-NYMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:05.073 Historical data download thread signaled to stop. | 2022-01-07 19:14:05.074 HD Request # 104 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for CLG22-NYMEX | 2022-01-07 19:14:05.074 HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2022-01-07 19:03:22.000000 | 2022-01-07 19:14:05.075 HD Request # 104 | Receiving Intraday data for CLG22-NYMEX starting at 2022-01-07 19:03:34.374000 | 2022-01-07 19:14:05.075 Added 14 Time and Sales records to Intraday data file for CLG22-NYMEX after download. | 2022-01-07 19:14:05.077 HD Request # 104 | Timestamp of first Intraday data file record written: 2022-01-07 19:03:34.374000 | 2022-01-07 19:14:05.077 HD Request # 104 | Completion time: 2s | 2022-01-07 19:14:05.078 HD Request # 104 | Intraday data download complete for CLG22-NYMEX. Unique request ID: 70 | 2022-01-07 19:14:05.078 Removing historical data download ID 70. | 2022-01-07 19:14:05.078 Real-time Intraday chart data file updates started for CLG22-NYMEX | 2022-01-07 19:14:05.078 Opened cached Intraday file: C:\SierraChart\Data\CLG22-NYMEX.scid. Thread ID: 8064 | 2022-01-07 19:14:05.086 Intraday chart data file opened for CLG22-NYMEX | 2022-01-07 19:14:05.086 HD Request # 104 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:14:05.086 Triggering next historical data download in queue. | 2022-01-07 19:14:05.086 HD Request # 105 | Downloading Intraday chart data for XBTH22-BMEX to the file XBTH22-BMEX.scid. Service: bitmex | 2022-01-07 19:14:05.086 HD Request # 105 | Download start date-time: 2022-01-07 19:13:33.000000. File last date-time: 2022-01-07 19:13:33.000000 | 2022-01-07 19:14:05.086 HD Request # 105 | Using server: ds12.sierracharts.com port 10149 | 2022-01-07 19:14:05.086 Socket (5) | Creating socket. | 2022-01-07 19:14:05.087 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:05.087 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-01-07 19:14:05.087 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:07.122 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:07.122 Socket (0) | CloseSocket call. | 2022-01-07 19:14:07.122 Socket (5) | Closed. | 2022-01-07 19:14:07.122 HD Request # 105 | Error downloading historical Intraday data for XBTH22-BMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:07.122 Added historical Intraday data request for XBTH22-BMEX to the queue. | 2022-01-07 19:14:07.122 Triggering next historical data download in queue. | 2022-01-07 19:14:07.122 Historical data download thread signaled to stop. | 2022-01-07 19:14:07.122 HD Request # 105 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XBTH22-BMEX | 2022-01-07 19:14:07.122 HD Request # 105 | Completion time: 2s | 2022-01-07 19:14:07.123 HD Request # 106 | Downloading Intraday chart data for XBTH22-BMEX to the file XBTH22-BMEX.scid. Service: bitmex | 2022-01-07 19:14:07.123 HD Request # 106 | Download start date-time: 2022-01-07 19:13:33.000000. File last date-time: 2022-01-07 19:13:33.000000 | 2022-01-07 19:14:07.124 HD Request # 106 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-07 19:14:07.124 Socket (5) | Creating socket. | 2022-01-07 19:14:07.124 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:07.124 Socket (5) | Connecting to IP: 64.38.174.180. | 2022-01-07 19:14:07.124 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:09.177 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:09.177 Socket (0) | CloseSocket call. | 2022-01-07 19:14:09.177 Socket (5) | Closed. | 2022-01-07 19:14:09.177 HD Request # 106 | Error downloading historical Intraday data for XBTH22-BMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:09.177 Added historical Intraday data request for XBTH22-BMEX to the queue. | 2022-01-07 19:14:09.177 Triggering next historical data download in queue. | 2022-01-07 19:14:09.177 Historical data download thread signaled to stop. | 2022-01-07 19:14:09.177 HD Request # 106 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XBTH22-BMEX | 2022-01-07 19:14:09.177 HD Request # 106 | Completion time: 2s | 2022-01-07 19:14:09.178 HD Request # 107 | Downloading Intraday chart data for XBTH22-BMEX to the file XBTH22-BMEX.scid. Service: bitmex | 2022-01-07 19:14:09.178 HD Request # 107 | Download start date-time: 2022-01-07 19:13:33.000000. File last date-time: 2022-01-07 19:13:33.000000 | 2022-01-07 19:14:09.178 HD Request # 107 | Using server: ds4.sierracharts.com port 10149 | 2022-01-07 19:14:09.178 Socket (5) | Creating socket. | 2022-01-07 19:14:09.179 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:09.179 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-01-07 19:14:09.179 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:11.223 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:11.223 Socket (0) | CloseSocket call. | 2022-01-07 19:14:11.223 Socket (5) | Closed. | 2022-01-07 19:14:11.223 HD Request # 107 | Error downloading historical Intraday data for XBTH22-BMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:11.224 Historical data download thread signaled to stop. | 2022-01-07 19:14:11.224 HD Request # 107 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XBTH22-BMEX | 2022-01-07 19:14:11.224 HD Request # 107 | Add time&sales data | Remembered last file record date-time: 2022-01-07 19:13:33.000000 | 2022-01-07 19:14:11.224 HD Request # 107 | Receiving Intraday data for XBTH22-BMEX starting at 2022-01-07 19:13:44.464000 | 2022-01-07 19:14:11.224 Added 7 Time and Sales records to Intraday data file for XBTH22-BMEX after download. | 2022-01-07 19:14:11.225 HD Request # 107 | Timestamp of first Intraday data file record written: 2022-01-07 19:13:44.464000 | 2022-01-07 19:14:11.225 HD Request # 107 | Completion time: 2s | 2022-01-07 19:14:11.226 HD Request # 107 | Intraday data download complete for XBTH22-BMEX. Unique request ID: 71 | 2022-01-07 19:14:11.226 Removing historical data download ID 71. | 2022-01-07 19:14:11.226 Real-time Intraday chart data file updates started for XBTH22-BMEX | 2022-01-07 19:14:11.226 Opened cached Intraday file: C:\SierraChart\Data\XBTH22-BMEX.scid. Thread ID: 8064 | 2022-01-07 19:14:11.233 Intraday chart data file opened for XBTH22-BMEX | 2022-01-07 19:14:11.233 HD Request # 107 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:14:11.233 Triggering next historical data download in queue. | 2022-01-07 19:14:11.233 HD Request # 108 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: equities.us | 2022-01-07 19:14:11.233 HD Request # 108 | Download start date-time: 2021-07-05 19:14:11.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:14:11.234 HD Request # 108 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2022-01-07 19:14:11.234 Socket (5) | Creating socket. | 2022-01-07 19:14:11.234 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:11.234 Socket (5) | Connecting to IP: 8.18.161.135. | 2022-01-07 19:14:11.234 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:13.262 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:13.262 Socket (0) | CloseSocket call. | 2022-01-07 19:14:13.262 Socket (5) | Closed. | 2022-01-07 19:14:13.262 HD Request # 108 | Error downloading historical Intraday data for AMZN. The network socket has been closed. Retrying download. | 2022-01-07 19:14:13.262 Added historical Intraday data request for AMZN to the queue. | 2022-01-07 19:14:13.262 Triggering next historical data download in queue. | 2022-01-07 19:14:13.262 Historical data download thread signaled to stop. | 2022-01-07 19:14:13.262 HD Request # 108 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for AMZN | 2022-01-07 19:14:13.262 HD Request # 108 | Completion time: 2s | 2022-01-07 19:14:13.262 HD Request # 109 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: equities.us | 2022-01-07 19:14:13.262 HD Request # 109 | Download start date-time: 2021-07-05 19:14:13.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:14:13.263 HD Request # 109 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-01-07 19:14:13.263 Socket (5) | Creating socket. | 2022-01-07 19:14:13.263 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:13.263 Socket (5) | Connecting to IP: 8.18.161.133. | 2022-01-07 19:14:13.263 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:15.324 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:15.324 Socket (0) | CloseSocket call. | 2022-01-07 19:14:15.324 Socket (5) | Closed. | 2022-01-07 19:14:15.324 HD Request # 109 | Error downloading historical Intraday data for AMZN. The network socket has been closed. Retrying download. | 2022-01-07 19:14:15.324 Added historical Intraday data request for AMZN to the queue. | 2022-01-07 19:14:15.324 Triggering next historical data download in queue. | 2022-01-07 19:14:15.324 Historical data download thread signaled to stop. | 2022-01-07 19:14:15.324 HD Request # 109 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for AMZN | 2022-01-07 19:14:15.324 HD Request # 109 | Completion time: 2s | 2022-01-07 19:14:15.324 HD Request # 110 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: equities.us | 2022-01-07 19:14:15.325 HD Request # 110 | Download start date-time: 2021-07-05 19:14:15.000000. File last date-time: 00:00:00.000000 | 2022-01-07 19:14:15.325 HD Request # 110 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2022-01-07 19:14:15.325 Socket (5) | Creating socket. | 2022-01-07 19:14:15.325 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:15.326 Socket (5) | Connecting to IP: 8.18.161.135. | 2022-01-07 19:14:15.326 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:17.375 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:17.375 Socket (0) | CloseSocket call. | 2022-01-07 19:14:17.375 Socket (5) | Closed. | 2022-01-07 19:14:17.375 HD Request # 110 | Error downloading historical Intraday data for AMZN. The network socket has been closed. Retrying download. | 2022-01-07 19:14:17.375 Historical data download thread signaled to stop. | 2022-01-07 19:14:17.375 HD Request # 110 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for AMZN | 2022-01-07 19:14:17.375 HD Request # 110 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-01-07 19:14:17.375 HD Request # 110 | Completion time: 2s | 2022-01-07 19:14:17.375 HD Request # 110 | Intraday data download complete for AMZN. Unique request ID: 72 | 2022-01-07 19:14:17.375 Removing historical data download ID 72. | 2022-01-07 19:14:17.375 Real-time Intraday chart data file updates started for AMZN | 2022-01-07 19:14:17.375 Opened cached Intraday file: C:\SierraChart\Data\AMZN.scid. Thread ID: 8064 | 2022-01-07 19:14:17.375 Intraday chart data file opened for AMZN | 2022-01-07 19:14:17.375 HD Request # 110 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:14:17.375 Triggering next historical data download in queue. | 2022-01-07 19:14:17.376 HD Request # 111 | Downloading Intraday chart data for BTCF22-CME to the file BTCF22-CME.scid. Service: cme | 2022-01-07 19:14:17.376 HD Request # 111 | Download start date-time: 2022-01-07 19:03:21.000000. File last date-time: 2022-01-07 19:03:21.000000 | 2022-01-07 19:14:17.376 HD Request # 111 | Using server: ds21.sierracharts.com port 10149 | 2022-01-07 19:14:17.376 Socket (5) | Creating socket. | 2022-01-07 19:14:17.376 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:17.376 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:14:17.376 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:19.427 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:19.427 Socket (0) | CloseSocket call. | 2022-01-07 19:14:19.427 Socket (5) | Closed. | 2022-01-07 19:14:19.427 HD Request # 111 | Error downloading historical Intraday data for BTCF22-CME. The network socket has been closed. Retrying download. | 2022-01-07 19:14:19.427 Added historical Intraday data request for BTCF22-CME to the queue. | 2022-01-07 19:14:19.427 Triggering next historical data download in queue. | 2022-01-07 19:14:19.427 Historical data download thread signaled to stop. | 2022-01-07 19:14:19.427 HD Request # 111 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BTCF22-CME | 2022-01-07 19:14:19.427 HD Request # 111 | Completion time: 2s | 2022-01-07 19:14:19.427 HD Request # 112 | Downloading Intraday chart data for BTCF22-CME to the file BTCF22-CME.scid. Service: cme | 2022-01-07 19:14:19.427 HD Request # 112 | Download start date-time: 2022-01-07 19:03:21.000000. File last date-time: 2022-01-07 19:03:21.000000 | 2022-01-07 19:14:19.428 HD Request # 112 | Using server: ds23.sierracharts.com port 10150 | 2022-01-07 19:14:19.429 Socket (5) | Creating socket. | 2022-01-07 19:14:19.429 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:19.429 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-07 19:14:19.429 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:21.489 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:21.489 Socket (0) | CloseSocket call. | 2022-01-07 19:14:21.489 Socket (5) | Closed. | 2022-01-07 19:14:21.489 HD Request # 112 | Error downloading historical Intraday data for BTCF22-CME. The network socket has been closed. Retrying download. | 2022-01-07 19:14:21.489 Added historical Intraday data request for BTCF22-CME to the queue. | 2022-01-07 19:14:21.489 Triggering next historical data download in queue. | 2022-01-07 19:14:21.489 Historical data download thread signaled to stop. | 2022-01-07 19:14:21.489 HD Request # 112 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BTCF22-CME | 2022-01-07 19:14:21.489 HD Request # 112 | Completion time: 2s | 2022-01-07 19:14:21.490 HD Request # 113 | Downloading Intraday chart data for BTCF22-CME to the file BTCF22-CME.scid. Service: cme | 2022-01-07 19:14:21.490 HD Request # 113 | Download start date-time: 2022-01-07 19:03:21.000000. File last date-time: 2022-01-07 19:03:21.000000 | 2022-01-07 19:14:21.491 HD Request # 113 | Using server: ds21.sierracharts.com port 10149 | 2022-01-07 19:14:21.491 Socket (5) | Creating socket. | 2022-01-07 19:14:21.491 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:21.491 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:14:21.491 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:23.514 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:23.514 Socket (0) | CloseSocket call. | 2022-01-07 19:14:23.514 Socket (5) | Closed. | 2022-01-07 19:14:23.514 HD Request # 113 | Error downloading historical Intraday data for BTCF22-CME. The network socket has been closed. Retrying download. | 2022-01-07 19:14:23.514 Historical data download thread signaled to stop. | 2022-01-07 19:14:23.514 HD Request # 113 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for BTCF22-CME | 2022-01-07 19:14:23.515 HD Request # 113 | Add time&sales data | Remembered last file record date-time: 2022-01-07 19:03:21.000000 | 2022-01-07 19:14:23.515 HD Request # 113 | Receiving Intraday data for BTCF22-CME starting at 2022-01-07 19:03:58.145000 | 2022-01-07 19:14:23.515 Added 4 Time and Sales records to Intraday data file for BTCF22-CME after download. | 2022-01-07 19:14:23.518 HD Request # 113 | Timestamp of first Intraday data file record written: 2022-01-07 19:03:58.145000 | 2022-01-07 19:14:23.518 HD Request # 113 | Completion time: 2s | 2022-01-07 19:14:23.518 HD Request # 113 | Intraday data download complete for BTCF22-CME. Unique request ID: 73 | 2022-01-07 19:14:23.518 Removing historical data download ID 73. | 2022-01-07 19:14:23.518 Real-time Intraday chart data file updates started for BTCF22-CME | 2022-01-07 19:14:23.518 Opened cached Intraday file: C:\SierraChart\Data\BTCF22-CME.scid. Thread ID: 8064 | 2022-01-07 19:14:23.527 Intraday chart data file opened for BTCF22-CME | 2022-01-07 19:14:23.527 HD Request # 113 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:14:23.527 Triggering next historical data download in queue. | 2022-01-07 19:14:23.527 HD Request # 114 | Downloading Intraday chart data for GCG22-COMEX to the file GCG22-COMEX.scid. Service: comex | 2022-01-07 19:14:23.527 HD Request # 114 | Download start date-time: 2022-01-07 19:03:24.000000. File last date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:23.528 HD Request # 114 | Using server: ds23.sierracharts.com port 10150 | 2022-01-07 19:14:23.528 Socket (5) | Creating socket. | 2022-01-07 19:14:23.528 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:23.528 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-07 19:14:23.528 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:25.559 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:25.559 Socket (0) | CloseSocket call. | 2022-01-07 19:14:25.559 Socket (5) | Closed. | 2022-01-07 19:14:25.559 HD Request # 114 | Error downloading historical Intraday data for GCG22-COMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:25.559 Added historical Intraday data request for GCG22-COMEX to the queue. | 2022-01-07 19:14:25.559 Triggering next historical data download in queue. | 2022-01-07 19:14:25.559 Historical data download thread signaled to stop. | 2022-01-07 19:14:25.559 HD Request # 114 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for GCG22-COMEX | 2022-01-07 19:14:25.560 HD Request # 114 | Completion time: 2s | 2022-01-07 19:14:25.560 HD Request # 115 | Downloading Intraday chart data for GCG22-COMEX to the file GCG22-COMEX.scid. Service: comex | 2022-01-07 19:14:25.560 HD Request # 115 | Download start date-time: 2022-01-07 19:03:24.000000. File last date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:25.560 HD Request # 115 | Using server: ds21.sierracharts.com port 10149 | 2022-01-07 19:14:25.560 Socket (5) | Creating socket. | 2022-01-07 19:14:25.560 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:25.560 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:14:25.560 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:27.601 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:27.601 Socket (0) | CloseSocket call. | 2022-01-07 19:14:27.601 Socket (5) | Closed. | 2022-01-07 19:14:27.601 HD Request # 115 | Error downloading historical Intraday data for GCG22-COMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:27.601 Added historical Intraday data request for GCG22-COMEX to the queue. | 2022-01-07 19:14:27.601 Triggering next historical data download in queue. | 2022-01-07 19:14:27.601 Historical data download thread signaled to stop. | 2022-01-07 19:14:27.601 HD Request # 115 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for GCG22-COMEX | 2022-01-07 19:14:27.601 HD Request # 115 | Completion time: 2s | 2022-01-07 19:14:27.601 HD Request # 116 | Downloading Intraday chart data for GCG22-COMEX to the file GCG22-COMEX.scid. Service: comex | 2022-01-07 19:14:27.601 HD Request # 116 | Download start date-time: 2022-01-07 19:03:24.000000. File last date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:27.602 HD Request # 116 | Using server: ds23.sierracharts.com port 10150 | 2022-01-07 19:14:27.602 Socket (5) | Creating socket. | 2022-01-07 19:14:27.602 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:27.602 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-07 19:14:27.602 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:29.651 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:29.651 Socket (0) | CloseSocket call. | 2022-01-07 19:14:29.651 Socket (5) | Closed. | 2022-01-07 19:14:29.652 HD Request # 116 | Error downloading historical Intraday data for GCG22-COMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:14:29.652 Historical data download thread signaled to stop. | 2022-01-07 19:14:29.652 HD Request # 116 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for GCG22-COMEX | 2022-01-07 19:14:29.652 HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:29.653 HD Request # 116 | Receiving Intraday data for GCG22-COMEX starting at 2022-01-07 19:03:33.812000 | 2022-01-07 19:14:29.653 Added 18 Time and Sales records to Intraday data file for GCG22-COMEX after download. | 2022-01-07 19:14:29.655 HD Request # 116 | Timestamp of first Intraday data file record written: 2022-01-07 19:03:33.812000 | 2022-01-07 19:14:29.655 HD Request # 116 | Completion time: 2s | 2022-01-07 19:14:29.656 HD Request # 116 | Intraday data download complete for GCG22-COMEX. Unique request ID: 74 | 2022-01-07 19:14:29.656 Removing historical data download ID 74. | 2022-01-07 19:14:29.656 Real-time Intraday chart data file updates started for GCG22-COMEX | 2022-01-07 19:14:29.656 Opened cached Intraday file: C:\SierraChart\Data\GCG22-COMEX.scid. Thread ID: 8064 | 2022-01-07 19:14:29.664 Intraday chart data file opened for GCG22-COMEX | 2022-01-07 19:14:29.664 HD Request # 116 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:14:29.664 Triggering next historical data download in queue. | 2022-01-07 19:14:29.664 HD Request # 117 | Downloading Intraday chart data for YMH22-CBOT to the file YMH22-CBOT.scid. Service: cbot | 2022-01-07 19:14:29.664 HD Request # 117 | Download start date-time: 2022-01-07 19:03:24.000000. File last date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:29.664 HD Request # 117 | Using server: ds21.sierracharts.com port 10149 | 2022-01-07 19:14:29.665 Socket (5) | Creating socket. | 2022-01-07 19:14:29.665 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:29.665 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:14:29.665 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:31.698 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:31.698 Socket (0) | CloseSocket call. | 2022-01-07 19:14:31.698 Socket (5) | Closed. | 2022-01-07 19:14:31.698 HD Request # 117 | Error downloading historical Intraday data for YMH22-CBOT. The network socket has been closed. Retrying download. | 2022-01-07 19:14:31.698 Added historical Intraday data request for YMH22-CBOT to the queue. | 2022-01-07 19:14:31.698 Triggering next historical data download in queue. | 2022-01-07 19:14:31.698 Historical data download thread signaled to stop. | 2022-01-07 19:14:31.698 HD Request # 117 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for YMH22-CBOT | 2022-01-07 19:14:31.698 HD Request # 117 | Completion time: 2s | 2022-01-07 19:14:31.698 HD Request # 118 | Downloading Intraday chart data for YMH22-CBOT to the file YMH22-CBOT.scid. Service: cbot | 2022-01-07 19:14:31.699 HD Request # 118 | Download start date-time: 2022-01-07 19:03:24.000000. File last date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:31.700 HD Request # 118 | Using server: ds23.sierracharts.com port 10150 | 2022-01-07 19:14:31.700 Socket (5) | Creating socket. | 2022-01-07 19:14:31.700 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:31.700 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-07 19:14:31.700 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:33.743 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:33.743 Socket (0) | CloseSocket call. | 2022-01-07 19:14:33.743 Socket (5) | Closed. | 2022-01-07 19:14:33.743 HD Request # 118 | Error downloading historical Intraday data for YMH22-CBOT. The network socket has been closed. Retrying download. | 2022-01-07 19:14:33.743 Added historical Intraday data request for YMH22-CBOT to the queue. | 2022-01-07 19:14:33.743 Triggering next historical data download in queue. | 2022-01-07 19:14:33.743 Historical data download thread signaled to stop. | 2022-01-07 19:14:33.743 HD Request # 118 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for YMH22-CBOT | 2022-01-07 19:14:33.743 HD Request # 118 | Completion time: 2s | 2022-01-07 19:14:33.744 HD Request # 119 | Downloading Intraday chart data for YMH22-CBOT to the file YMH22-CBOT.scid. Service: cbot | 2022-01-07 19:14:33.744 HD Request # 119 | Download start date-time: 2022-01-07 19:03:24.000000. File last date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:33.745 HD Request # 119 | Using server: ds21.sierracharts.com port 10149 | 2022-01-07 19:14:33.745 Socket (5) | Creating socket. | 2022-01-07 19:14:33.745 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:33.745 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:14:33.745 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:35.805 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:35.805 Socket (0) | CloseSocket call. | 2022-01-07 19:14:35.805 Socket (5) | Closed. | 2022-01-07 19:14:35.805 HD Request # 119 | Error downloading historical Intraday data for YMH22-CBOT. The network socket has been closed. Retrying download. | 2022-01-07 19:14:35.805 Historical data download thread signaled to stop. | 2022-01-07 19:14:35.805 HD Request # 119 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for YMH22-CBOT | 2022-01-07 19:14:35.805 HD Request # 119 | Add time&sales data | Remembered last file record date-time: 2022-01-07 19:03:24.000000 | 2022-01-07 19:14:35.806 HD Request # 119 | Receiving Intraday data for YMH22-CBOT starting at 2022-01-07 19:03:38.880000 | 2022-01-07 19:14:35.806 Added 35 Time and Sales records to Intraday data file for YMH22-CBOT after download. | 2022-01-07 19:14:35.809 HD Request # 119 | Timestamp of first Intraday data file record written: 2022-01-07 19:03:38.880000 | 2022-01-07 19:14:35.809 HD Request # 119 | Completion time: 2s | 2022-01-07 19:14:35.809 HD Request # 119 | Intraday data download complete for YMH22-CBOT. Unique request ID: 75 | 2022-01-07 19:14:35.809 Removing historical data download ID 75. | 2022-01-07 19:14:35.809 Real-time Intraday chart data file updates started for YMH22-CBOT | 2022-01-07 19:14:35.809 Opened cached Intraday file: C:\SierraChart\Data\YMH22-CBOT.scid. Thread ID: 8064 | 2022-01-07 19:14:35.814 Intraday chart data file opened for YMH22-CBOT | 2022-01-07 19:14:35.814 HD Request # 119 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:14:35.814 Triggering next historical data download in queue. | 2022-01-07 19:14:35.814 HD Request # 120 | Downloading Intraday chart data for 6EH22-CME to the file 6EH22-CME.scid. Service: cme | 2022-01-07 19:14:35.814 HD Request # 120 | Download start date-time: 2022-01-07 19:03:10.000000. File last date-time: 2022-01-07 19:03:10.000000 | 2022-01-07 19:14:35.814 HD Request # 120 | Using server: ds23.sierracharts.com port 10150 | 2022-01-07 19:14:35.814 Socket (5) | Creating socket. | 2022-01-07 19:14:35.815 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:35.815 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-07 19:14:35.815 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:37.860 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:37.860 Socket (0) | CloseSocket call. | 2022-01-07 19:14:37.860 Socket (5) | Closed. | 2022-01-07 19:14:37.860 HD Request # 120 | Error downloading historical Intraday data for 6EH22-CME. The network socket has been closed. Retrying download. | 2022-01-07 19:14:37.861 Added historical Intraday data request for 6EH22-CME to the queue. | 2022-01-07 19:14:37.861 Triggering next historical data download in queue. | 2022-01-07 19:14:37.861 Historical data download thread signaled to stop. | 2022-01-07 19:14:37.861 HD Request # 120 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for 6EH22-CME | 2022-01-07 19:14:37.861 HD Request # 120 | Completion time: 2s | 2022-01-07 19:14:37.861 HD Request # 121 | Downloading Intraday chart data for 6EH22-CME to the file 6EH22-CME.scid. Service: cme | 2022-01-07 19:14:37.861 HD Request # 121 | Download start date-time: 2022-01-07 19:03:10.000000. File last date-time: 2022-01-07 19:03:10.000000 | 2022-01-07 19:14:37.862 HD Request # 121 | Using server: ds21.sierracharts.com port 10149 | 2022-01-07 19:14:37.862 Socket (5) | Creating socket. | 2022-01-07 19:14:37.862 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:37.863 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-07 19:14:37.863 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:39.908 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:39.908 Socket (0) | CloseSocket call. | 2022-01-07 19:14:39.908 Socket (5) | Closed. | 2022-01-07 19:14:39.908 HD Request # 121 | Error downloading historical Intraday data for 6EH22-CME. The network socket has been closed. Retrying download. | 2022-01-07 19:14:39.908 Added historical Intraday data request for 6EH22-CME to the queue. | 2022-01-07 19:14:39.908 Triggering next historical data download in queue. | 2022-01-07 19:14:39.908 Historical data download thread signaled to stop. | 2022-01-07 19:14:39.908 HD Request # 121 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for 6EH22-CME | 2022-01-07 19:14:39.908 HD Request # 121 | Completion time: 2s | 2022-01-07 19:14:39.908 HD Request # 122 | Downloading Intraday chart data for 6EH22-CME to the file 6EH22-CME.scid. Service: cme | 2022-01-07 19:14:39.908 HD Request # 122 | Download start date-time: 2022-01-07 19:03:10.000000. File last date-time: 2022-01-07 19:03:10.000000 | 2022-01-07 19:14:39.909 HD Request # 122 | Using server: ds23.sierracharts.com port 10150 | 2022-01-07 19:14:39.909 Socket (5) | Creating socket. | 2022-01-07 19:14:39.909 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:14:39.909 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-07 19:14:39.909 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:14:41.957 * Socket (5) | CloseSocket call. | 2022-01-07 19:14:41.957 Socket (0) | CloseSocket call. | 2022-01-07 19:14:41.957 Socket (5) | Closed. | 2022-01-07 19:14:41.957 HD Request # 122 | Error downloading historical Intraday data for 6EH22-CME. The network socket has been closed. Retrying download. | 2022-01-07 19:14:41.958 Historical data download thread signaled to stop. | 2022-01-07 19:14:41.958 HD Request # 122 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for 6EH22-CME | 2022-01-07 19:14:41.958 HD Request # 122 | Add time&sales data | Remembered last file record date-time: 2022-01-07 19:03:10.000000 | 2022-01-07 19:14:41.959 HD Request # 122 | Receiving Intraday data for 6EH22-CME starting at 2022-01-07 19:03:39.283000 | 2022-01-07 19:14:41.959 Added 10 Time and Sales records to Intraday data file for 6EH22-CME after download. | 2022-01-07 19:14:41.962 HD Request # 122 | Timestamp of first Intraday data file record written: 2022-01-07 19:03:39.283000 | 2022-01-07 19:14:41.962 HD Request # 122 | Completion time: 2s | 2022-01-07 19:14:41.963 HD Request # 122 | Intraday data download complete for 6EH22-CME. Unique request ID: 76 | 2022-01-07 19:14:41.963 Removing historical data download ID 76. | 2022-01-07 19:14:41.963 Real-time Intraday chart data file updates started for 6EH22-CME | 2022-01-07 19:14:41.963 Opened cached Intraday file: C:\SierraChart\Data\6EH22-CME.scid. Thread ID: 8064 | 2022-01-07 19:14:42.005 Intraday chart data file opened for 6EH22-CME | 2022-01-07 19:14:42.005 HD Request # 122 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:14:42.005 Triggering next historical data download in queue. | 2022-01-07 19:14:42.005 No download requests in the queue to start downloads for. | 2022-01-07 19:14:42.005 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-07 19:15:04.075 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-01-07 19:15:04.075 DTC Client socket (4) | CloseSocket call. | 2022-01-07 19:15:04.075 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-01-07 19:15:04.075 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-07 19:15:04.075 DTC Client socket (4) | Closed. | 2022-01-07 19:15:04.075 DTC Client socket (0) | CloseSocket call. | 2022-01-07 19:15:04.076 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-07 19:15:04.076 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-07 19:15:04.076 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-01-07 19:15:06.099 DTC Client socket (4) | Creating socket. | 2022-01-07 19:15:06.099 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-01-07 19:15:06.099 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2022-01-07 19:15:06.099 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-07 19:15:06.145 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-07 19:15:06.145 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-07 19:15:06.145 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-07 19:15:06.215 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-07 19:15:06.215 SC DTC Data with Market Depth | Received logon response. | 2022-01-07 19:15:06.903 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-07 19:15:06.903 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-07 19:15:06.903 SC DTC Data with Market Depth | Successfully connected. | 2022-01-07 19:15:06.903 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-07 19:15:06.903 Added historical Intraday data request for XBTH22-BMEX to the queue. | 2022-01-07 19:15:06.903 Intraday data recording state for symbol XBTH22-BMEX is set to download 'Pending'. | 2022-01-07 19:15:06.903 Triggering next historical data download in queue. | 2022-01-07 19:15:06.903 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTH22-BMEX | 2022-01-07 19:15:06.903 HD Request # 123 | Downloading Intraday chart data for XBTH22-BMEX to the file XBTH22-BMEX.scid. Service: bitmex | 2022-01-07 19:15:06.903 HD Request # 123 | Download start date-time: 2022-01-07 19:14:49.000000. File last date-time: 2022-01-07 19:14:49.000000 | 2022-01-07 19:15:06.904 HD Request # 123 | Using server: ds12.sierracharts.com port 10149 | 2022-01-07 19:15:06.904 Socket (5) | Creating socket. | 2022-01-07 19:15:06.904 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:15:06.904 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-01-07 19:15:06.905 SC DTC Data with Market Depth | Received security definition for symbol XBTH22-BMEX | 2022-01-07 19:15:07.029 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:15:08.956 * Socket (5) | CloseSocket call. | 2022-01-07 19:15:08.956 Socket (0) | CloseSocket call. | 2022-01-07 19:15:08.956 Socket (5) | Closed. | 2022-01-07 19:15:08.956 HD Request # 123 | Error downloading historical Intraday data for XBTH22-BMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:15:08.958 Added historical Intraday data request for XBTH22-BMEX to the queue. | 2022-01-07 19:15:08.958 Triggering next historical data download in queue. | 2022-01-07 19:15:08.958 Historical data download thread signaled to stop. | 2022-01-07 19:15:08.958 HD Request # 123 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XBTH22-BMEX | 2022-01-07 19:15:08.958 HD Request # 123 | Completion time: 2s | 2022-01-07 19:15:08.958 HD Request # 124 | Downloading Intraday chart data for XBTH22-BMEX to the file XBTH22-BMEX.scid. Service: bitmex | 2022-01-07 19:15:08.958 HD Request # 124 | Download start date-time: 2022-01-07 19:14:49.000000. File last date-time: 2022-01-07 19:14:49.000000 | 2022-01-07 19:15:08.959 HD Request # 124 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-07 19:15:08.959 Socket (5) | Creating socket. | 2022-01-07 19:15:08.960 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:15:08.960 Socket (5) | Connecting to IP: 64.38.174.180. | 2022-01-07 19:15:08.960 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:15:10.996 * Socket (5) | CloseSocket call. | 2022-01-07 19:15:10.996 Socket (0) | CloseSocket call. | 2022-01-07 19:15:10.996 Socket (5) | Closed. | 2022-01-07 19:15:10.996 HD Request # 124 | Error downloading historical Intraday data for XBTH22-BMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:15:10.997 Added historical Intraday data request for XBTH22-BMEX to the queue. | 2022-01-07 19:15:10.997 Triggering next historical data download in queue. | 2022-01-07 19:15:10.997 Historical data download thread signaled to stop. | 2022-01-07 19:15:10.997 HD Request # 124 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XBTH22-BMEX | 2022-01-07 19:15:10.997 HD Request # 124 | Completion time: 2s | 2022-01-07 19:15:10.997 HD Request # 125 | Downloading Intraday chart data for XBTH22-BMEX to the file XBTH22-BMEX.scid. Service: bitmex | 2022-01-07 19:15:10.997 HD Request # 125 | Download start date-time: 2022-01-07 19:14:49.000000. File last date-time: 2022-01-07 19:14:49.000000 | 2022-01-07 19:15:10.998 HD Request # 125 | Using server: ds4.sierracharts.com port 10149 | 2022-01-07 19:15:10.998 Socket (5) | Creating socket. | 2022-01-07 19:15:10.998 Socket (5) | New receive buffer size: 5242880 | 2022-01-07 19:15:10.999 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-01-07 19:15:10.999 Socket (5) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-01-07 19:15:13.035 * Socket (5) | CloseSocket call. | 2022-01-07 19:15:13.035 Socket (0) | CloseSocket call. | 2022-01-07 19:15:13.035 Socket (5) | Closed. | 2022-01-07 19:15:13.035 HD Request # 125 | Error downloading historical Intraday data for XBTH22-BMEX. The network socket has been closed. Retrying download. | 2022-01-07 19:15:13.035 Historical data download thread signaled to stop. | 2022-01-07 19:15:13.036 HD Request # 125 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XBTH22-BMEX | 2022-01-07 19:15:13.036 HD Request # 125 | Add time&sales data | Remembered last file record date-time: 2022-01-07 19:14:49.000000 | 2022-01-07 19:15:13.036 HD Request # 125 | Receiving Intraday data for XBTH22-BMEX starting at 2022-01-07 19:15:08.109000 | 2022-01-07 19:15:13.036 Added 3 Time and Sales records to Intraday data file for XBTH22-BMEX after download. | 2022-01-07 19:15:13.038 HD Request # 125 | Timestamp of first Intraday data file record written: 2022-01-07 19:15:08.109000 | 2022-01-07 19:15:13.038 HD Request # 125 | Completion time: 3s | 2022-01-07 19:15:13.039 HD Request # 125 | Intraday data download complete for XBTH22-BMEX. Unique request ID: 77 | 2022-01-07 19:15:13.039 Removing historical data download ID 77. | 2022-01-07 19:15:13.039 Real-time Intraday chart data file updates started for XBTH22-BMEX | 2022-01-07 19:15:13.039 Opened cached Intraday file: C:\SierraChart\Data\XBTH22-BMEX.scid. Thread ID: 8064 | 2022-01-07 19:15:13.049 Intraday chart data file opened for XBTH22-BMEX | 2022-01-07 19:15:13.049 HD Request # 125 | Enabling Intraday chart updating for symbol. | 2022-01-07 19:15:13.049 Triggering next historical data download in queue. | 2022-01-07 19:15:13.049 No download requests in the queue to start downloads for. | 2022-01-07 19:15:13.049 |
[2022-01-07 21:07:40] |
User93731 - Posts: 83 |
Dear Support: I highly suspect this problem is caused by the blocking of my campus security. IS it possible that you could proved my the port numbers SC is using ? Last time, when I asked our campus to unlock the port numbers from its security wall for Interactive Brokers, then after it is unlocked, I could be able to connect to SC with datafeed from IB and trading at SC. So Maybe, the port number that related to STOCK data is locked by our campus. (but the odd thing is that the futures data did coming in, although is loaded quite slowly.. if It normal for the first time to load this chart? I have been here for 5 hours and and some studies like Stochastic on the chart, cannot even have enough data to show the it complete shape.. Your timely replay is greatly appreciate as our school semester will start soon. Many thanks. |
[2022-01-07 22:02:49] |
John - SC Support - Posts: 38380 |
You have the following error showing up for all the symbols: Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it.
This could definitely be related to having blocked ports. If you feel this is the most likely cause, then refer to the following for the port and IP information: Data/Trading Service Connection and Symbol Issues: 1.6. Internet Ports and IP Addresses used by Sierra Chart Data Services We also want to point out that you are not setup to receive any real-time data from us. This means that data from the CME and EUREX would be streaming but delayed by 10-15 minutes (depending on exchange). The data for U.S. Equities, however, would only update at the timing defined by the setting Global Settings >> Data/Trade Service Settings >> Intraday Download Interval for Non-Real-Time Symbols. And with each update, the data will be 15-20 minutes behind the actual time. If you are wanting real-time data, then refer to the following for futures data: Denali Exchange Data Feed And refer to the following for the U.S. Equities data: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-07 22:27:58] |
Dear Support: Should I Ask All port numbers listed below to be unlocked? Which is 443, 10048, 10047, 10045, 10060, 10043, 10042. and 80, 10149, 10150, or 10159. or just some of them? (1) For Sierra Chart provided real-time data services, the Internet ports are 443, 10048, 10047, 10045, 10060, 10043, 10042. There is also the Global Settings >> Data/Trade Service Settings >> SC Server Settings >> Always use Port 443 for Real-Time Data setting. However, when using data compression, this port will not be used. (2) Depending upon the particular symbol, and the selected Data or Trading service, historical Daily data from Sierra Chart data servers will be downloaded on ports 80, 10149, 10150, or 10159. For most of the supported Data and Trading services historical Intraday data is downloaded on port 10149 or 10150. However, port 80 can also be used. More information about this can be found in the Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server section. Best, HW |
[2022-01-07 22:31:52] |
It is best to ask to have all of them made available.
[2022-01-07 23:07:27] |
Dear Support: Delayed data (SC data- All service) is what our students could afford now, so we will stick with this delayed data. But thank you for the information for the read-time data and I will pass to them. Are these ports numbers ( 443, 10048, 10047, 10045, 10060, 10043, 10042. and 80, 10149, 10150, or 10159) are only for the real-time data? Will unlock them help us to receive the delayed data? . My SC at my home office, which run your (SC data -All Service), indicate that there are UDP port 22903, Listening port 11099, Historical Data port 11098. Should I also include these port numbers for my campus to unlock as well? Also When I go to Global Settings >> Data/Trade Service Settings >> Intraday Download Interval for Non-Real-Time Symbols., my SC is setup as 60 min. I change it to 10 mins. Will this work to alter the delay from 60 mins to 10 mins? Best, HW |
[2022-01-10 15:09:09] |
You need to unlock those ports in order to get the delayed data as well. My SC at my home office, which run your (SC data -All Service), indicate that there are UDP port 22903, Listening port 11099, Historical Data port 11098. Should I also include these port numbers for my campus to unlock as well?
You do not need to open those ports to the outside. Those are used to communicate with sub-instances on the same computer, or in the case of the UDP port, for UDP connections from the same computer. Also When I go to Global Settings >> Data/Trade Service Settings >> Intraday Download Interval for Non-Real-Time Symbols., my SC is setup as 60 min. I change it to 10 mins. Will this work to alter the delay from 60 mins to 10 mins?
That will change the update interval for symbols that are not real-time or delayed streaming. Such as U.S. Equities. The lowest you can set it is 20 minutes. The updates will occur at that interval, but the data will still be behind the actual market by 10-20 minutes (depending on exchange). Again, this has nothing to do with the delayed streaming data - that data delay is set by us to be 10-20 minutes (depending on exchange). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-17 20:16:19] |
Dear Support: My campus finally unlock this port numbers and These data flows in to my compute lab. However, the timing of these data is off. This is is the delayed data which comes from your SC Data-ALL service and the timing is actually marked AHEAD For example, it is 1:13PM (13:11) on 01/17/2022, and the last data point is shown coming in at 19:00 on 01/17/2022. How could I fix it? Many thanks. |
[2022-01-17 20:26:49] |
I changed its time zone to Denver and it is fixed now. Many thanks
