Date/Time: Tue, 04 Mar 2025 21:59:02 +0000
instrument tick value config
View Count: 539
[2022-01-07 16:30:47]
User12089 - Posts: 365
setting the instrument tick value config in Symbol Settings seems to have effect only in the calcs in the Trade Activity Log but doesnt seem to be taken into account in the real-time NPL shown on the chart
is there a config which can make the NPL take into account the new tick money value in Custom Symbol settings?
[2022-01-07 18:38:36]
John - SC Support - Posts: 38371
If you are referring to the Currency Value per Tick, then changing it in the Symbol Settings would not affect any of the calculations in the charts. The system is going to use the value as it is set in Chart >> Chart Settings >> Advanced Settings 2 >> Currency Value per Tick.
When you change the value in the Symbol Settings, then that is setting what any new Chart that uses that symbol will have for that value.
[2022-01-07 19:04:07]
perfect - worked as advised
