Date/Time: Tue, 23 Jun 2026 04:45:41 +0000
Sierrachart with AMPFUTURES
View Count: 768
[2022-01-07 15:21:31]
Fesiek - Posts: 1
I bought data for exchanges at AMPfutures. How do I log in to Sierrachart to use the data purchased in AMP?
[2022-01-07 15:52:17]
First your account is expired.
Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Account Control Panel" on the Sierra Chart software menu.
On the displayed webpage, click on "Activate Services".
Or you can also go to this page in your browser:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
Login with your Sierra Chart Account Name and Password.
2. Choose the particular Service Package that you want to automatically renew and press the "Update/Set" button.
3. Add sufficient credit to your Services Balance using any of the available payment options:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
For further information, refer to:
Sierra Chart Purchase and License Information: Renewing Access
You then need to set Sierra Chart to use either CQG or Rithmic. Depending upon what system AMP has set up your account on. Refer to:
CQG Trading Platform Service: Setup Instructions
Rithmic Trading Platform Service: Setup Instructions
In either case, you will need to use the Denali data feed to avoid market data issues you will likely encounter:
Denali Exchange Data Feed
