Date/Time: Tue, 04 Mar 2025 22:24:08 +0000
Translating Symbols when I have a lot of files
View Count: 523
[2022-01-06 20:53:21] |
petertrump - Posts: 1 |
Thanks, we did it. One more question, after change of data feed i notice symbol changed, for example for ES: from ESH22-CME to ESH22_FUT_CME. That is ok, I can use this "translate symbol to current service". But I have a lot CME data files (indexes and currencies - a lot of gigs). Do I have to download it again? Previous files are also from your data feed, so for ES it looks like ESH22-CME.scid and new one ESH22_FUT_CME.scid. |
[2022-01-06 21:35:33] |
Yes, the data has to be downloaded again. The internal data format is a little different with the decimal point.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-06 21:35:49
