Date/Time: Tue, 04 Mar 2025 21:59:03 +0000
Account advice opening
View Count: 651
[2022-01-06 14:21:53]
User764155 - Posts: 10
I would use your platform for place orders and I would ask to you if you can advice me broker for open an account with good reputaion and good commissions I would trade the emini S&p-500 future, I find Advantage future and Amp interesting but also I would that your platform works well with the broker for place orders...
Congratulation for your software.
Regards
Alfonso
[2022-01-06 15:20:03]
First, we recommend using our Teton order routing service:
This is the very best choice.
A list of brokers is listed at step 2 in the setup instructions:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2022-01-06 18:15:06]
I ask you if Sierra Futures is ok for use your platform with Teton.
Thank you
Alfonso
[2022-01-07 15:52:56]
1+1=10 - Posts: 270
Hi Alfonso,
If by Sierra Futures you mean the brokerage at the following link, then yes, at the bottom in small text it says: "Sierra Futures a division of Stage 5 Trading Corp. is a member of NFA and is subject to NFA's regulatory oversight and examinations."
https://sierrafutures.stage5trading.com/
Higher up in the Traders Benefit Section it says:
* Denali Data Feed
* FREE Sierra Chart Order Routing
Good luck!
[2022-01-07 16:48:43]
Sierra Futures is associated with Stage 5 and Stage 5 does support the Teton order routing service.
And also Sierra Futures is not affiliated with Sierra Chart. They are independent.
Date Time Of Last Edit: 2022-01-07 16:49:14
[2022-01-07 17:52:46]
Thank you.
