Date/Time: Tue, 04 Mar 2025 22:25:48 +0000
Broker/FCM Denali & Teton
View Count: 706
[2022-01-06 02:47:06]
User866150 - Posts: 14
A little confused.
Would like to use SC, including Denali feed & Teton routing.
Is it only required to contact Doorman Trading to create/fund an account & inform them I will be using Teton?
Or is it required I use a broker such as Stage5 as well as Doorman Trading (FCM)? I just created an account with AMP but see they're not supporting SC routing.
[2022-01-06 15:33:21]
You could have an account direct with Dorman. But you have to check on their minimum requirements for this. Or you could open the account through Stage 5.
We recommend contacting them both and discussing this with them.
Here is the full documentation for the Teton Order Routing service:
Date Time Of Last Edit: 2022-01-06 15:33:49
[2022-01-07 15:54:33]
1+1=10 - Posts: 270
Also consider Sierra Futures. Stage 5 seems to have started them to directly appeal to SC traders using Denali & Teton. $250 account minimum. $3.6 RT on ES.
https://sierrafutures.stage5trading.com/
