Date/Time: Tue, 04 Mar 2025 22:11:21 +0000
Cancel button vs. J27 in Spreadsheet
View Count: 440
[2022-01-06 02:18:35]
j4ytr4der_ - Posts: 946
I've been exploring possibilities with the Order Allocation feature. I'm sure it will be expanded at some point, but for now I was looking to enhance it with the use of a spreadsheet system.
The trouble I've run into is that while the Cancel button in the Trade Window (or the hotkey) will actually pass the command through to all the allocated accounts, cell J27 triggering true on the "master" chart/DOM, does not.
Would it be tremendously difficult to make the Cancel feature of a SSfT study pass through to allocated accounts just as if the cancel button was pressed? Thanks for considering!
[2022-01-07 16:45:09]
We will be implementing linking between orders when they are sent to other allocated accounts.
So that when you cancel the original order, the other linked orders to the other accounts will cancel as well.
[2022-01-07 17:08:10]
OK, and this will also apply if it was the spreadsheet that initiated the cancel, yes?
REALLY looking forward to more with the OA feature. =)
Date Time Of Last Edit: 2022-01-07 17:08:29
