Date/Time: Wed, 05 Mar 2025 01:46:22 +0000
[User Discussion] - Placing order 10 below market
View Count: 567
[2022-01-05 22:44:21]
User963221 - Posts: 20
Newbie here, 100% trading off of a DOM, is there a way to place an order 10 ticks from current bid/ask?
Like trading ES and I want to enter an order 10 ticks below current bid, as the ES moves up and down quickly, this would be extremely useful in my scalping methods.
Kurt
[2022-01-06 14:27:54]
Sawtooth - Posts: 4179
Go to Global Setting >> ChartDOM Settings and set the Order Types as in the attached pic.
These not the default settings, but should be, IMO.
Date Time Of Last Edit: 2022-01-06 14:31:12
imageChartDOM settings.PNG / V - Attached On 2022-01-06 14:26:40 UTC - Size: 14.11 KB - 153 views
[2022-01-06 17:12:46]
User90125 - Posts: 715
So basically you ignore all RIGHT-CLICK actions on the DOM?
From a UX/UI perspective, that seems kind of counterintuitive to me, especially where STOP or STOP-LIMIT orders are concerned.
Date Time Of Last Edit: 2022-01-06 17:16:27
[2022-01-07 17:24:08]
I also discovered today I can create a keyboard shortcut that will place an order x number of ticks away. This is exactly what I needed.
[2022-01-09 18:25:59]
User536779 - Posts: 3
i would be interested in that as well. Care to share how you did the keyboard shortcut, or point to how. thanks.
[2022-01-09 18:42:52]
Global Settings -> Customize Keyboard Shortcuts -> Custom Trading Keyboard Shortcuts
Choose one of the customs and off to the right is Customize Trading Command
Let me know if this doesn't work for you and I will create a short video; I have included a screenshot of one that I did.
imagesierra Help Custom Keyboard Key.JPG / V - Attached On 2022-01-09 18:42:26 UTC - Size: 196.67 KB - 135 views
