Date/Time: Tue, 04 Mar 2025 21:41:24 +0000
live trading account not assigned
View Count: 449
[2022-01-05 17:32:56]
User510286 - Posts: 1
I'm getting delayed data, although I'm logging in with a live account. Please assign my live amp trading account.
[2022-01-05 17:44:08]
John - SC Support - Posts: 38369
Everything on your account looks good and your Setup for the Denali data is good.
Therefore, check to make sure that the setting for Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds is set to Yes. If it is not, then change it to Yes, and then select File >> Disconnect followed by File >> Connect to Data Feed.
If this is already set to Yes, then we would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
