Date/Time: Wed, 16 Sep 2026 21:44:10 +0000
AMP Futures - link trading account to Sierra Chart
View Count: 1480
[2022-01-05 15:26:20]
Dan the Man - Posts: 111
How do I attach my Amp Futures trading account to Sierra Charts.
I would like to place trades through Sierra Charts.
Also, I thinking about trading NYSE stocks.
What data package do I need and I would like to place stock trades through Sierra Charts.
Kind Regards,
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=59033
[2022-01-05 16:56:43]
John - SC Support - Posts: 47917
In order to connect your Sierra Chart to your AMP account, you need to know what order routing service you are setup with at AMP - either CQG or Rithmic. You will then need to follow the appropriate instructions based on the order routing service you are setup to use.
For CQG, follow these instructions:
CQG Trading Platform Service: Setup Instructions
For Rithmic, follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
For U.S. Stocks, you can get the data from us through our Sierra Chart Exchange Data Feed. Just be aware that it does not include market depth data at this time, but we are working on a new data feed for US Stocks that will include the market depth - it should be ready in a month or two and will be part of our Denali Exchange Data Feed.
In order to setup the stock data, follow the instructions at the following link and activate the U.S. Equities exchange:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
In terms of trading stocks, the only broker we work with that supports stock trading is Interactive Brokers. Refer to our information for Interactive Brokers (including Setup Instructions) at the following link:
Interactive Brokers Trading Service
Also, if you do end up with multiple trading accounts (like AMP for futures and IB for stocks) then we recommend having different installations of Sierra Chart for each service. Refer to the following for how to install another Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
[2022-01-06 01:25:43]
Hi
Thank-you for your help with Amp and Great News regarding US stock data through your Sierra Chart Exchange Data Feed
Kind Regards,
Daniel
