Date/Time: Tue, 26 Nov 2024 04:21:26 +0000
Error message from FXCM FIX?
View Count: 1817
[2014-04-07 17:01:24] |
kraut - Posts: 20 |
Is the message "ORA-20105: Order price did not pass validation" generated by the FXCM FIX API or Sierra Chart? Please find context below. --- 2014-04-07 08:53:03 | FXCM FIX (Recv) >> 8=FIX.4.49=37735=934=809349=FXCM50=E10R252=20140407-08:53:01.43856=[private_data_deleted]19915;DAS 19915: ZDas Exception ORA-20105: Order price did not pass validation 60=20140407-08:53:01102=99336=FXCM434=[private_data_deleted]19915;DAS 19915: ZDas Exception ORA-20105: Order price did not pass validation 10=115 Date Time Of Last Edit: 2014-04-07 17:01:49
[2014-04-07 17:10:46] |
This is from the FXCM server. This just means the price of the order was not considered valid.
