Date/Time: Wed, 09 Sep 2026 22:46:29 +0000
Numbers bars Calculated Values 2 Dominant Ask or Bid Percentage Coloration
View Count: 1095
[2022-01-05 14:43:20]
User123891 - Posts: 20
I am using numbers bars and the calculated values 2 study. How do I get the numbers to be colored the same value as the ask/bid dominant percentage? If I color as the base gradient, it colors the ask bid dominant percentage in the same way as the result of price movement as the bar. This happens even if I base the study on ask/bid difference bars. I want the coloration to be the same as the ask/bid percentage, not the price movement of the bar. So if the bar goes up even though the ask bid percentage is down, the coloration that want reflects the ask/bid percentage and not price. Thanks
[2022-01-05 15:33:53]
John - SC Support - Posts: 47822
The specific setup you are wanting is not supported. The Numbers Bars Calculated Values coloring is simply a minimum to maximum coloring over either all the bars or (for some Subgraphs) a daily basis. Refer to the following for more information on how the Numbers Bars Calculated Values are colored:
Numbers Bars: Calculated Values Background Coloring Logic
