Date/Time: Tue, 22 Apr 2025 18:28:08 +0000
teton order routing
View Count: 1084
[2022-01-05 14:22:40] |
NoahZ - Posts: 4 |
Good morning . as of monday the 3rd i contacted my broker( edge clear- i have Phillip Capital as my clearing firm ) and had them set up my account for teton order routing. and was informed by one of their brokers that i was ready to go. this morning i updated my SC to the latest version and attempted to connect via the instructions SC provided and the error message- no trade accounts assigned populated. is there something more on my end i need to do?
[2022-01-05 14:40:31] |
Follow the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions Make sure you are selecting the correct service. It is "Teton CME Order Routing". And make sure you select the correct clearing firm. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-05 14:43:04] |
NoahZ - Posts: 4 |
both are correct
[2022-01-05 14:52:30] |
Therefore, contact your broker and give them your exact username as it is shown in "Help >> About". And have them make sure the trading account is assigned to that username.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-05 14:52:59
[2023-03-16 21:43:09] |
User788517 - Posts: 1 |
Does IBKR support this?
[2023-03-17 03:27:09] |
Sierra_Chart Engineering - Posts: 19305 |
No they do not.
