Date/Time: Tue, 04 Mar 2025 21:43:59 +0000
Downloads issue
View Count: 452
[2022-01-05 10:57:16] |
User871949 - Posts: 1 |
I am trying to download the charts from the download page and every time it stops after a few seconds or so. I have attached the screenshot of what I am seeing. I am running Microsoft on parallel, on my mac book. I don't know if this is why, or weather that info helps you understand the issue. Many thanks |
![]() Attachment Deleted. |
[2022-01-05 12:31:29] |
This is a common problem we hear about when you are using a set up like you describe. Here is the relevant documentation: Software Download: Resolving 'Access is Denied' Errors (Resolving 'Access is Denied' Errors) Try using the ZIP Installer instead as explained in that section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-05 12:33:53
