Date/Time: Thu, 24 Sep 2026 01:01:17 +0000
TETON order routing service - market data problem
View Count: 1188
[2022-01-05 08:20:59]
VolTrader73 - Posts: 139
Hello.
I migrated to the TETON service from Rithmic.
I followed the steps to change the server settings.
I have the green light indicator working (top left green bar in the main window)
There is no market data.
I want to translate current chart symbols also they are setup to Daneli with Rithmic.
Searching for symbols I only get a strange list of CME symbols that have only the Emini SP500 and another future.
Nothing else available (NQ or MNQ for example.
The only symbol working is ESH22_FUT_CME and this is strange as with Rithmic and Daneli the symbol format was ESH22-CME which worked with Daneli and Rithmic bur also doesnt work.
I try NQH22_FUT_CME and MNQH22_FUT_CME but they dont work.
Please advise.
Date Time Of Last Edit: 2022-01-05 11:24:51
[2022-01-05 12:04:46]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
Date Time Of Last Edit: 2022-01-05 12:05:03
[2022-01-05 13:06:55]
I have followed all the instructions above by their order. The only symbols available in the CME right now are 1ES, ES , 3EMD and EuroDollar. Also available are some non defined futures such as OZWH22. That is it.
I have also just sent you the message log for analysis.
Before clearing the log I noticed it said something about alternative market data service not supported.
Maybe this can help.
Please advise.
Date Time Of Last Edit: 2022-01-05 13:16:29
[2022-01-05 13:18:15]
We apologize, we just now realized you are running an older version. You must update. Instructions:
You are seeing symbols which we use with the CME test environment.
Date Time Of Last Edit: 2022-01-05 14:41:47
[2022-01-06 00:00:19]
That was the issue.
Am getting data and execution is working as well.
Thank you
