Date/Time: Tue, 04 Mar 2025 21:11:58 +0000
Manage Drawings - Manage Chart Drawings Window - Select All Issue
View Count: 567
[2022-01-05 06:40:17]
User719512 - Posts: 299
Select All remains Checked after you select all and Delete all drawings. If you refresh your chart, and want to delete all drawings again, you must uncheck Select All, then re-check Select All.
Suggestion:
Uncheck select all in the code if Delete is performed.
[2022-01-05 14:19:22]
Sierra_Chart Engineering - Posts: 18654
We will look into this.
