Date/Time: Tue, 04 Mar 2025 21:39:12 +0000
inconsistent data
View Count: 665
[2022-01-04 22:40:01]
coachted - Posts: 368
I am curious why if I run the study TPO Value area Lines for the the info does not match the info from running a TPO chart...for example I am looking at the weekly value area hi value area low fro last week, and the valuea area poc, via the study, reflects the POC at 4772.50 but if I run a weekly tpo chart the poc the TPO chart reflects 4775.75. Please advise
[2022-01-04 22:46:57]
John - SC Support - Posts: 38369
The first thing to do is to ensure that you re not running both the TPO and the TPO Value Area Lines at the same time. You can NOT have the TPO Value Area Lines on the TPO study and get proper results. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
Assuming that the above is not the issue, then you need to ensure that you have the exact same settings for both the TPO and the TPO Value Area Lines.
If you still have an issue then we would need to see your Chartbook with both of the charts in it with the appropriate studies on them. Refer to the following instructions, except we would need 2 charts, not just 1:
[2022-01-04 22:54:06]
whats odd is the value area hi and low match the poc does not
[2022-01-04 23:17:25]
just reviewed the settings and they seem to macth...i have attached the cht book here...the es wwkly profile and the es rotations are the ones I am comparing information to....
attachmentES charts.Cht - Attached On 2022-01-04 23:17:02 UTC - Size: 151.81 KB - 239 views
[2022-01-05 14:57:01]
You are making a comparison between a 1 minute chart and a Renko 4 tick chart. Therefore, there are going to be differences in the TPO Value Area/POC results between these charts. In particular, a non-time-based chart will give slightly different results since the times for a bar do not line up exactly with the sub-period times, therefore some of the TPOs are not accounted for in the same way as they are with a time-based chart.
[2022-01-05 18:28:49]
so which is correct the tpo chart or the renko?
[2022-01-05 18:30:42]
The chart with the TPO profile is going to have the most accurate information. The Value Area Lines on a Renko is going to miss some of the information.
[2022-01-05 18:33:28]
thank you
