Date/Time: Wed, 30 Sep 2026 03:23:49 +0000
Evaluating package 12 - Stock data (UVXY e.g.) not streaming
View Count: 885
| [2022-01-04 22:18:15] |
| U993720 - Posts: 2 |
Futures data are streaming (ESH22 e.g., delayed), but stock data are static (e.g. UVXY). I'm new to stock data and found no help. Could You please help? |
| [2022-01-04 22:37:41] |
| John - SC Support - Posts: 48062 |
What you are seeing is normal and correct. We only have Delayed Streaming Data for the CME Group and EUREX. The Stock data we have is updated at most every 20 minutes and is always behind the exchange by at least 15 minutes. Refer to the following regarding the historical intraday data: Sierra Chart Historical Data Service If you want to have real-time data for Futures, then refer to the following: Denali Exchange Data Feed And if you want real-time data for other exchanges (including U.S. Equities data), then refer to the following: Sierra Chart Exchange Data Feed Note that in the next few months we will have a new data feed for U.S. Equities that will be part of the Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
