Date/Time: Tue, 04 Mar 2025 21:39:36 +0000
How 2 insert a footprint in chart-DOM
View Count: 800
[2022-01-04 21:03:46]
MEETsierra1407 - Posts: 5
I try to install a footprint in the chart DOM. Can somebody tell me how to install this study? See attached picture for example.
Also want to ad these 2 to horizontal lines that move with the market in the DOM? (also see picture)
Thanks,
Dirck
imageFootnote in chart dom.jpg / V - Attached On 2022-01-04 20:59:34 UTC - Size: 295.95 KB - 231 views
[2022-01-04 22:09:48]
John - SC Support - Posts: 38369
The profile in the DOM is not a study, it is just a matter of turning on the Show Volume Bars for the particular columns for which you want to see the profiles. You can then left/right adjust the data/profiles in the columns to get them "back to back" like in your image. Refer to the following:
Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns)
The 2 lines look like the Chart DOM Daily High and Chart DOM Daily Low lines. These can be added to a DOM by Enabling the color setting for these items. Refer to the following:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Daily High Line
[2022-01-04 23:24:32]
Yes Found it,
Thanks again! Very helpful!
