Date/Time: Tue, 04 Mar 2025 21:35:20 +0000
SYMBOL TO CREATE H/J WTI on NYMEX
View Count: 539
[2022-01-04 20:58:23] |
User266438 - Posts: 17 |
Hi could someone tell me the The Formula and symbol to set up the NYMEX H/J WTI Spread please . Regards Tony |
[2022-01-04 21:43:17] |
John - SC Support - Posts: 38369 |
Refer to the following for how to look up exchange traded spreads: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads Otherwise, refer to the Spread Order Entry study at the following link: Spread Order Entry Study And another option is to use the Custom Calculated Symbols to be able to view the spread. Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-05 19:07:56] |
Hi I had a ice live feed and the symbol for the H/J Brent spread was _S_SP_CBH22_CBJ22.FUT_SPREAD.IFEU .What Symbol do i have to put in for the H/J WTI on the NYMEX Market Please . |
[2022-01-05 21:35:06] |
The symbol will depend on what trading service you are connected to. The best way to get the symbol is to follow the instructions for the Exchange Traded Spreads to pull up the list of spreads and select the one you want, which will fill in the symbol information for you. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
