Date/Time: Thu, 06 Mar 2025 09:38:27 +0000
Advantage Futures vs Phillip Capital
View Count: 1554
[2022-01-04 17:50:06]
theunknowntrader - Posts: 112
Are they the same or is one better than the other?
I am looking at clearing firms to switch over to Teton
[2022-01-04 18:19:43]
Aside from commissions and margins, anything else is different?
[2022-01-04 20:33:27]
Edge Clear - Posts: 17
hello @theunknowntrader ,
Advantage and Phillip Capital are two separate FCM's that offer their own unique advantages based on what traders needs and goals are. Both happen to have access to Teton Order Routing. It can be difficult to answer your question completely without learning more about you and your trading goals.
Edge Clear works with a number of FCM's that have access to Teton Order Routing. We ask that you contact us and one of our personal brokers will walk you through all the details and point you to the direction we feel is best.
You can contact us here: https://edgeclear.com/contact-us/
Edge Clear LLC
P: 773.832.8320 | TF: 844-TRADE20
edgeclear.com
The risk of trading futures and options can be substantial. Trading derivatives carries a high degree of risk, and may not be suitable for all investors. All information, publications, social media and reports, including this specific material, used and distributed by Edge Clear LLC shall be construed as a solicitation. Edge Clear does not distribute research reports, employ research analysts, or maintain a research department as defined in CFTC Regulation 1.71. Please note that there can be a material conflict of interest for your account based on your FCM choice, platform use, and data feed execution. You should be aware that NFA does not have regulatory oversight authority over underlying or spot virtual currency products or transactions or virtual currency exchanges, custodians or markets. Past performance is not necessarily indicative of future results.
Date Time Of Last Edit: 2022-01-04 20:33:38
[2022-01-04 22:33:03]
Thanks for your help Edgeclear. I just filled out an application form through for Phillip as FCM through EdgeClear.
[2022-02-01 00:59:59]
User379468 - Posts: 508
unknown, can you share with us your findings and how you chose?
[2022-02-01 01:08:09]
I chose EdgeClear because
1) Advantage Futures form was too complicated, Edgeclear was basically Phillip Capital's
2) EdgeClear uses Phillip which is larger FCM than Advantage Futures is
3) Account minimum for Edgeclear is lower than Advantage/Stage 5
[2022-02-01 01:34:18]
Nevertheless, Advantage and Stage 5 are top notch! it just depends on what you need.
[2022-02-01 01:34:45]
Thanks, could you DM me?
