Date/Time: Tue, 04 Mar 2025 21:37:53 +0000
[User Discussion] - Teton Routing - Stage5 Trading
View Count: 780
[2022-01-04 17:25:53]
User491428 - Posts: 87
Hello, you recommend borkers who support the new order routing, ok. AMP is known to be a stable, secure broker. What about the ones you recommend? They are secure about financial stability?
[2022-01-04 17:49:11]
John - SC Support - Posts: 38369
The brokers that support the new Teton Order Routing Service are listed at Step #2 at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
We do not make any specific recommendations nor do we have any information on their financial stability. You would need to find that out, or you can see if others have information they can share.
[2022-01-04 18:15:15]
Brokers do not hold customer money typically.
You would have to look at the financials of Advantage, Phillip Capital, Dorman who support the Teton order routing service. The brokers are irrelevant in this regard.
Brokers who are in the position of Introducing Broker definitely do not hold customer money.
Date Time Of Last Edit: 2022-01-04 18:17:12
[2022-01-05 00:03:06]
User837706 - Posts: 14
Hello User491428
Every month FCMs declare their financial position to the CFTC.
You can check the info at the webpage below:
https://www.cftc.gov/MarketReports/financialfcmdata/index.htm
This is the latest info available:
https://www.cftc.gov/sites/default/files/2021-12/01-%20FCM%20Webpage%20Update%20-%20October%202021.pdf
Hope this helps.
