Date/Time: Tue, 04 Mar 2025 21:22:36 +0000
Chart Graphics Settings
View Count: 483
[2022-01-04 16:31:27]
User841161 - Posts: 248
Is there a way to copy Chart Graphics Settings from one chart to another- not using the global graphics settings.
[2022-01-04 17:23:46]
John - SC Support - Posts: 38369
The only way is to use the chart you have setup the way you want as a "Template" and copy that chart and then update the symbol. Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
