Date/Time: Tue, 04 Mar 2025 21:07:31 +0000
StopLmt order - numbers in brackets meaning?
View Count: 599
[2022-01-04 14:46:17] |
User58008 - Posts: 32 |
Dear Sierra, I am confused about what is the meaning of the numbers in brackets next to the value of my stoploss order, I meant B/StopLmt... I enclose printscreen, could you just tell me what does the number 16500.50 mean? Thank you |
[2022-01-04 16:21:06] |
John - SC Support - Posts: 38369 |
That is the price that the Limit order will be placed when the Stop is hit. Refer to the information at the following link for how that value is set: Order Types: Attached Stop Limit Order Inputs (Trade Window >> Targets) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-04 16:53:13] |
OK, I can see, the Limit order was app. 12 points far eventhough I had set 6 ticks, but now it seems working after confirming once again. Also - can I hide this Limit order price from showing on the order line (the brackets), it is very annoying for me to see it all the time, I got confused couple of times. I would like to see just the Stop price. |
[2022-01-04 17:43:06] |
Refer to the following settings to control what is displayed on the order lines: Global Trade Settings Windows: Order Quantity (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
