Date/Time: Tue, 04 Mar 2025 21:43:21 +0000
is there any list of supported brokers that SC can work with?
View Count: 594
[2022-01-04 11:39:32]
User61576 - Posts: 445
I could not find anything though I do remember there was something like this
will appreciate it if you could share
thanks
[2022-01-04 13:50:50]
Mercrastius - Posts: 45
I'm not sure if this is a complete list but here you go...
https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php
[2022-01-04 13:53:19]
Yes that is the list:
We strongly recommend and insist upon using brokers that support the Teton order routing service:
Date Time Of Last Edit: 2022-01-04 13:53:30
