Date/Time: Mon, 16 Sep 2024 19:19:44 +0000
Indicator Question
View Count: 933
[2014-04-07 12:02:32] |
infpz - Posts: 826 |
I've looking for a study that will give me the maximum amount of price tick movement(IN 1 DIRECTION ONLY) over a certain candlestick period. Example 1 hour -- CT 357 ticks over last 30 days. I would be using it for over extension trading.
[2014-04-07 16:34:09] |
This does not sound like something Sierra Chart has. It would have to be custom programmed. Although we are not sure we fully understand it.
