Date/Time: Tue, 04 Mar 2025 21:26:24 +0000
Error with sc.SaveChartbook()
View Count: 486
[2022-01-04 09:46:19] |
User99735 - Posts: 234 |
One of my customers gets the following error when using a study which calls function sc.SaveChartbook() "File compression not supported on file system. D:\SierraChart - FUTURE TRADING\SierraChartInstance_2\Data\F.US.EPH22.scid. Windows error code 1: Incorrect function." |
[2022-01-04 12:06:18] |
They are not running the Windows operating system. That error message can be safely disregarded.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-04 12:06:25
[2022-01-04 13:17:30] |
Customer is using Windows 10 OS.
[2022-01-04 13:20:33] |
Ok in our experience, this error message is encountered on Wine with Linux. They need to find out why compression is not supported on the file system. They need to get that resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
