Date/Time: Tue, 04 Mar 2025 21:42:08 +0000
[User Discussion] - Knoxville Divergence Alert Sounds Issue
View Count: 547
[2022-01-04 06:43:42] |
Ez - Posts: 53 |
Hi, there seems to be an issue with the Knoxville Divergence Alert sounds being off by one number. For instance, if I set the the audio alert to "Alert sound #1", it plays "Alert sound #2". I downloaded to source code hoping it could be a quick fix I could re-compile myself but since the code is quite old, it's a bit beyond my tinkering ability to convert at the moment (I'm working on learning though). Is it possible someone could look at this and fix? Or convert the cpp file to something that could compile to an external dll? thx much link: https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/KnoxvilleDivergence.cpp |
