Date/Time: Tue, 04 Mar 2025 21:22:14 +0000
How to setup second computer with live Denali data feed on both computers
View Count: 690
[2022-01-04 04:57:53]
monk - Posts: 13
I currently have a funded, live account on one computer using Denali data feed.
Tonight I installed SierraChart on my second computer. I also enabled the following...
Number Of Systems (Computers)
2 System(s)
Note that once you set the number of systems the value will stick for the current Calendar Month if you have exchanges active.
If you have exchange options enabled, you will be charged for again for the user of the additional computer/system.
For the current month, the account is set for 2 system(s).
For the upcoming month, the account is set to renew with 2 system(s).
But when I try to Connect to Data Feed on the second computer, the first computer receives the following msg >>>
"Yoursession was closed due to a concurrent session"
What additional settings do I need to change on the new, second computer? I want to be able to submit live trades on both computers.
Thank you.
[2022-01-04 06:26:54]
That error is from CQG! They do not allow more than one connection!
Use the Teton Order Routing Service to have as many connections as you need:
And no, AMP does not support this service (assuming you are using them). You have to move your trading account to another broker. Do not wait around for them. You should be able to get better commissions.
You are paying $0.10 per fill (with Teton you will pay nothing), you have substandard service with CQG in so many ways. And have limitations like this. Why use CQG. It makes completely no sense at all. This is why we are going to raise the price of CQG, and dramatically reduce its usage among Sierra Chart users.
Date Time Of Last Edit: 2022-01-07 16:58:03
