Date/Time: Tue, 04 Mar 2025 21:39:17 +0000
bar by bar review... synchronize charts on global cursor
View Count: 863
[2022-01-03 21:50:40]
User112372 - Posts: 7
I want to move bar by bar through two charts to review the day's market action.
I know how to use global cursor, and as long as I am moving the crosshairs along in a sweeping motion, the second chart keeps up. But when I try to go bar by bar to see corresponding moves, the "second chart" will not move bar by bar. How do I fix this?
[2022-01-03 23:45:35]
John - SC Support - Posts: 38369
It sounds like you want to use the Linking option for Scroll Position. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
[2022-01-04 04:19:36]
Yes, exactly right! Thank you so much.
