Date/Time: Tue, 04 Mar 2025 21:24:59 +0000
Show and Manipulate Orders On All Charts in a Chartbook
View Count: 1610
[2022-01-03 21:03:27] |
absorrel4 - Posts: 97 |
I have two different symbols in my chartbook....one is the Nasdaq 100 Mini and one is the Nasdaq 100 Micro. I am using the MICRO to sharpen my trading skills with minimal cost. I use the MINI chart for order set up and I enter the order on the MICRO chart. Question. Once I enter the order on the MICRO chart, how do I have it also show up on the MINI chart (i.e, all charts in the Chartbook)? I want the order to show up on both charts (pending and once filled) AND I want to be able to adjust the order on either chart (MINI or MICRO chart)? How can I accomplish this? Thank you... |
[2022-01-03 23:43:17] |
John - SC Support - Posts: 38369 |
In general, a chart is tied to the symbol for that chart and hence any trades that one symbol would not show up on another. But, if you use the Chart >> Chart Settings >> Trade and Current Quote Symbol and set this to the symbol of another chart, then you would be able to see/modify the orders for the specified symbol. Just be aware, you are really specifying a different symbol to use for trading on that chart. For more information, refer to the following: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-04 01:08:14] |
Yes you need to use the Trade and Current Quote Symbol setting: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-04 01:08:48
[2022-01-04 02:44:30] |
Perfect...exactly what I wanted...thanks.
