Date/Time: Tue, 26 Nov 2024 13:28:19 +0000
FTSE 100 and CAC40 Futures with AMP/TTNet
View Count: 2860
[2014-04-07 10:50:30] |
User16114 - Posts: 153 |
When I duplicate a 30 minute chart and then change symbol to FDAX-201406-Eurex, the chart data appears. When I change the symbol to Z-201406-NYSE_Liffe (FTSE100) or jFCE-201406-NYSE_Liffe (CAC40), no chart data appears. I am using a package 5 SC instance with AMP/TTNet Trading Service and no other data subscription. My shortest chart periodicity is 30 minutes. What can I do to have 30 minute charts for FTSE100 and CAC40 futures? |
[2014-04-07 18:12:10] |
Refer to help topic 7:Http://www.sierrachart.com/index.php?l=doc/helpdetails7.html When I change the symbol to Z-201406-NYSE_Liffe (FTSE100) or jFCE-201406-NYSE_Liffe (CAC40), no chart data appears. What can I do to have 30 minute charts for FTSE100 and CAC40 futures?
Use the Sierra Chart Historical Data Service: https://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-16 10:42:52] |
User13216 - Posts: 5 |
Re the FTSE100 underlying, Daily and Intraday.. I use IB, where the ticker used to be Z in TWS and Z-I-LIFFE in Sierra Chart. Now that ICE have taken over Liffe, this no longer works. The ticker Z still works in TWS, so is there a new ticker to use in Sierra Chart? |
[2014-05-16 13:56:54] |
User24804 - Posts: 19 |
I'm having trouble with that too since the March changeover Tried all sorts of ways of entering tickers. |
[2014-05-16 16:31:25] |
We will check on what the current symbol should be and update the Global Symbol Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-16 16:43:47
[2014-05-16 16:43:11] |
This is the new symbol format: Z-######-LIFFE-GBP-1000 Update the Symbol Settings as explained here to get this symbol: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Only use this new format. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-16 16:55:05] |
Thank you. I need the Underlying Index ticker. That symbol format looks like one for Futures. (I tried it anyway, in File>Open>Intraday chart - using Z-201406-LIFFE-GBP-1000 and it came up Symbol is unknown) |
[2014-05-16 17:35:19] |
For the cash FTSE use this symbol: Z-IND-LIFFE-GBP (I tried it anyway, in File>Open>Intraday chart - using Z-201406-LIFFE-GBP-1000 and it came up Symbol is unknown) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-16 18:36:33] |
Tried Z-IND-LIFFE-GBP for new Historical chart and for new Intraday chart (1-min). Result in both cases - a blank/empty chart window |
