Date/Time: Tue, 04 Mar 2025 21:22:04 +0000
First, thank you - Second, I need some help!
View Count: 510
[2022-01-03 19:10:17]
User114952 - Posts: 2
Thank you for standing up for what ya'll believe in!
Second, I am receiving an error that I do not have a trading account set. I have searched the board, and my user profile but cannot find a location to set my trading account to AMP/CQG. Can you please direct me to the correct spot on the site?
Also, I have read a few posts about CQG not being recommended due to connection issues/errors and them blaming SC for them -- Can you please give your top broker/FCM recommendation?
Thank you, and all the best!
Date Time Of Last Edit: 2022-01-03 20:05:47
[2022-01-03 21:29:29]
For now to connect to CQG you need to follow these instructions (Refer to setup instructions on this page):
CQG Trading Platform Service
Yes there are issues with CQG, and limitations and they are also a competitor and we want users to use our Teton service and it is far superior and will cost nothing extra (Can be a huge dollars savings):
At step 2 in the set up instructions on that page, are a list of brokers. As far as what FCM typically we would recommend Advantage or Phillip Capital. Dorman is also supported.
[2022-01-04 23:42:37]
Thanks for the response!
I'll start looking into another broker - I appreciate the advice and transparency!
All the best.
