Date/Time: Tue, 04 Mar 2025 21:36:30 +0000
Remote Support
View Count: 651
[2022-01-03 19:06:29]
User516363 - Posts: 3
Grant me remote support I will pay the cost....
[2022-01-03 20:51:59]
??? there is no message?? Will I get paid remote support. I have not been able to connect my trading account at AMP broker
[2022-01-03 23:36:24]
John - SC Support - Posts: 38369
We only give remote support when we feel that it is something we need to do. We just do not have the time to give remote support for everyone when requested.
If you just need help getting setup or understanding how to use Sierra Chart, then we recommend contacting Diana Pena at the following link:
https://bio.link/dianapena
From the statement you have made about connecting Sierra Chart to your AMP account, then what you need to do is to follow the appropriate Setup Instructions depending on what order routing service AMP has you setup to use. Most likely it is CQG, but it could be Rithmic.
If you are setup with CQG, then follow these instructions:
CQG Trading Platform Service: Setup Instructions
If you are setup with Rithmic, then follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
