Date/Time: Tue, 04 Mar 2025 21:26:39 +0000
Chartbook freezes sierra
View Count: 681
[2022-01-03 15:46:38] |
User909252 - Posts: 20 |
Loading up an old chartbook and it freezes Sierra.
Private File |
[2022-01-03 20:25:27] |
John - SC Support - Posts: 38369 |
We are not having any issues opening the chartbook, but the symbol that is being used in the old chartbook is not correct for CQG. So what we think is occurring is simply that nothing is loading and it appears that Sierra Chart is frozen. Here are the steps that we would like for you to take to ensure that everything is working properly: - Open the chartbook. - Select the CW menu and select the chart listed in there. This ensures that even if the chart is hidden that it will then display properly. - Select Edit >> Translate Symbols to Current Service. This will convert the symbol to the symbol methodology being used by your trading service (which appears to be CQG). Let us know if you still do not get anything, or if Sierra Chart is actually freezing at any of these steps where you can not interact with the software. Also note that if everything above works properly, then you will get a notice that the symbol needs to be rolled over, since the symbol in use is from the M contract of 2019. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-04 14:11:17] |
Yes it actually freezes (says Not responding). So I can't interact to change the symbol.
[2022-01-04 14:38:23] |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
