Date/Time: Tue, 04 Mar 2025 21:19:45 +0000
teton routing
View Count: 806
[2022-01-03 15:26:14] |
User143551 - Posts: 104 |
when is the last day you will stop using transact as a broker ,are you going to update to more than one dom to trade on ,smothing like shotgun dom
[2022-01-03 17:37:51] |
We do not know the answer to this question right now. However, we strongly recommend that you move to the Teton order routing service as soon as possible because it is superior to everything else and you will save on commissions through the brokers that support it: Sierra Chart Teton Futures Order Routing Multiple trading DOMs are currently supported. Just open as many as you want. Instructions: Chart Trading and the Chart DOM: Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-03 17:43:03
[2022-01-03 18:59:18] |
is there amy way i can get you to come on my computer and help me set the trading dom up
[2022-01-03 23:19:32] |
John - SC Support - Posts: 38369 |
is there amy way i can get you to come on my computer and help me set the trading dom up 'This is not something that we have the time to do, as we are just too busy with everything else. We recommend Diana Pena as someone that can help you get setup the way you want. You can contact her at the following: https://bio.link/dianapena For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
