Date/Time: Tue, 26 Nov 2024 13:44:04 +0000
[Locked] - When Eurex will be supported by Teton
View Count: 3086
[2022-01-03 10:08:09] |
Snusmumrik - Posts: 8 |
Hello, Could you please update us on the status of the Eurex support for Teton? I would like to switch but I need Teton as well. Many thanks! |
[2022-01-03 12:10:05] |
This is in development, but it is involved to support EUREX order routing. It is hard to give an estimate at this point. Maybe two months away.
[2022-02-23 22:47:04] |
RIFT - Posts: 124 |
Is there any news when Eurex will be supported?
[2022-02-23 23:15:54] |
No we cannot give a time. This is too unpredictable.
[2022-03-11 22:36:03] |
User379468 - Posts: 508 |
Will you support ICE with Teton?
[2022-04-13 07:44:37] |
Meritus - Posts: 164 |
Hi Support, Is there any update on when Eurex will be available on Teton? Is it potentially likely to be in the second half of 2022 rather than something likely to happen in the next month or so? Can I also request that you will continue offering CQG / Eurex at least until the Teton service is able to support Eurex? Obviously if you pull CQG away before an alternative is available (for Eurex) it would be slightly unfair Thanks Date Time Of Last Edit: 2022-04-13 09:10:36
[2022-04-20 15:05:59] |
We are not sure about this. We are holding on this because the cost is very high and there are a lot of details to the implementation. We may do it, but we just have it on hold for now. Support for CQG EUREX order routing will remain. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-20 15:08:04
[2022-08-02 09:34:35] |
Hello, Do you have any news on this front? Can we expect EUREX on Teton this year or should we stick with current arrangements? Thanks Date Time Of Last Edit: 2022-08-02 09:35:11
[2022-08-02 10:14:53] |
EUREX trading is not coming to Teton. That has been decided against. There is just not enough demand for it and the cost is too high and the world is too unpredictable and we have better things to do with our time which are massively more productive. should we stick with current arrangements? Yes
[2023-01-03 15:19:00] |
kremat0r - Posts: 47 |
Not coming at all, or we need to just wait? Really for now, I feel there is no alternative to Interactive Brokers to trade Eurex comfortable. We have only CQG, which you don't even recommended and Interactive with their API, which sometimes is confusing. Really EU market is so small? |
[2023-01-03 15:37:58] |
Rithmic works well with Eurex
[2023-01-03 15:43:12] |
Sierra_Chart Engineering - Posts: 17179 |
Yes: Really EU market is so small?
[2023-01-03 20:38:55] |
I really dont want Rithmic na CQG. So I need to come back to old option Interactive and wait till Teton will be available ;) sooner or later. |
[2023-03-09 14:32:46] |
I'm really getting confused. In almost every post you as Sierrachart complain about CQG and Rhitmic, not even talking about Interactive Brokers, you call it straight "SHIT" :) At the same time if someone wants to trade EUREX there is no alternative, nothing, really nothing. I know lot of people waiting for EUREX on Teton. I'm small doing around 1000-2000 contracts per month, but I know a lot of people doing way more, way more. I can even pay small fee, but PLEASE do it. I may even beg you :) Thank you |
[2023-03-09 15:05:34] |
User90125 - Posts: 715 |
+1 on Eurex via Teton
[2023-05-13 06:08:34] |
RIFT - Posts: 124 |
+1 Eurex trading is currently the only way to trade via Interactive Brokers (high commission and margin, very poor platform) or execution via TT if you want to avoid measuring with CQG and Rithmic. I personally don't like the TT Dom, the shortcut keys function is very bad and that's important when the speed is high. TT is expensive and you still have to pay for it because there is no other solution. So it would be very good if SC offered Eurex routing! I believe some prop trading companies would switch from TT to SC Teton if Eurex trading is possible and the risk parameters could be set in SC like in TT. TT charting is just terrible. I don't understand why you think Eurex is too small, FGBL and FESX are high volume markets. Margin and commission are also good and if the routing were possible, it would also be interesting for traders who are not currently trading Eurex. Date Time Of Last Edit: 2023-05-14 07:28:59
[2023-08-03 07:21:11] |
Hello Sierra team, Any news here? Any progress? Thank you |
[2023-08-07 09:09:56] |
TGK4711 - Posts: 17 |
[2023-10-18 07:01:54] |
BrMa - Posts: 80 |
[2023-10-18 08:32:44] |
DF52 - Posts: 19 |
+1 And charge for it. Personally I wouldn't expect it to be free like the CME routing. |
[2023-10-19 02:20:53] |
User61168 - Posts: 403 |
+1
[2023-11-10 06:52:09] |
User309106 - Posts: 1 |
Also curious to know when this will be supported.
[2023-11-14 06:23:29] |
There are definitively no plans to be supporting EUREX. The world is changing, and that should be obvious to us all and we are not going to be investing anytime in this, under no circumstances. Soon, we are all going to be facing much much worse problems. Kinetic war (https://en.wikipedia.org/wiki/Kinetic_military_action), famine and energy shortages which are all interrelated. There should not be denial of these facts. These things are coming to us all. We are not going to be wasting the last days of our lives as we know them, hopefully we survive, messing around with so much complexity and all of the bureaucracy with this type of trading functionality, referring to MiFID. We are at the precipice of a worldwide disaster. Anyone who is in denial of this, is hiding from the truth. There is no way what is going on the world, is not going to result, in shortages of food, and energy and an expansion of the Kinetic war. The basic point, is we must focus our efforts, on what helps us truly. And work towards a world of freedom and independence, from those trying to kill us and divide us (as a humanity) from behind the scenes. And we have long talked about our own exchange, and that effort is going on in the background. It is not going to be like a EUREX futures exchange, no, but it has other purposes. This is where our focus is. On our own development efforts and projects which have so much more potential. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-14 08:47:00
[2023-11-23 23:13:26] |
This is from a user: I live in Europe and have an account with Interactive Brokers. Unfortunately they decided to implement the regulatory MIFID II rules in a way that hinders my trading. Every time I enter an order in TWS using hotkeys, a mandatory popup is displayed with a link to a “Cost Impact” document. This has to be clicked away. According to their support this is by design now. Which brings me to my questions. Further confirmation of why exactly we have stayed away from EUREX order routing. We do not need this burden from these damn communists/socialists/tyrants in the world (Not referring to EUREX or Deutsche Borse, but instead those in the EU creating these rules) imposing their way upon all of us. We must instead put our efforts towards freedom and independence. This is what we previously stated: and all of the bureaucracy with this type of trading functionality, referring to MiFID.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-23 23:16:22
[2023-11-24 00:18:02] |
For the record regarding EUREX Trading, we actually did program to the EUREX FIX LF interface for order routing. But it was the MiFID related implementation and maintenance and support, which is all an immense amount of work, and the cost of connectivity, which made the whole thing not worth it to continue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-24 00:18:45
