Date/Time: Sun, 13 Sep 2026 03:19:45 +0000
Teton
View Count: 1041
[2022-01-03 08:58:36]
User185037 - Posts: 21
Здравствуйте! Я крайне заинтересован этой услугой! Правильно ли я понял, что услуга предоставляется бесплатно, при использовании мною, как и раньше, 11 пакета?
Правильно ли я понял, что с этой услугой мне не нужно будет платить за CME данные для непрофессионалов, в размере 11$?
Правильно ли я понял, что ордера будут обрабатываться быстрее напрямую на бирже?
Могу ли я пользоваться этой услугой имея счет в AMP Clearing? Если, да, то моя плата за использование Sierra Chart составит только плату за пакет? Я буду освобожден от комиссий CQG?
Получается, что у этой услуги одни плюсы?
Благодарю за ответы!
[2022-01-03 22:37:44]
John - SC Support - Posts: 47854
From Google Translate:
Hello! I am extremely interested in this service! Did I understand correctly that the service is provided free of charge, when I use, as before, 11 packages?
Did I understand correctly that with this service I will not have to pay for CME data for non-professionals, in the amount of $ 11?
Did I understand correctly that orders will be processed faster directly on the exchange?
Can I use this service with an AMP Clearing account? If yes, is my Sierra Chart fee only package fee? Will I be exempt from CQG fees?
It turns out that this service has only advantages?
Thanks for the answers![/quote]
Yes, this service has no order routing fees, at least for the next few months. We might change this position in the future, but we do not have any specific plans.
You will still need to pay for the data.
From what we have seen, the orders are processed faster than some other services.
The Teton Order Routing Service is not currently supported by AMP. AMP states that they expect to support it - eventually, but we do not know when - it is really up to them at this point to decide whether to offer it or not.
[2022-01-04 06:06:27]
You still do have to pay for Sierra Chart. Sierra Chart is not free. The Teton order routing service does not change the cost of service package prices.
