Date/Time: Wed, 27 Nov 2024 10:36:51 +0000
Inquiry about Teton and exchange fees
View Count: 1369
[2022-01-03 02:38:00] |
jdevela - Posts: 1 |
Hi there, I have a question about fee differentials if switching to Teton. I am currently paying for the CME Exchange fee of $33 plus the Package 11 Advance + Denali Feed for $46. Would there be any changes if switching to the Teton service? Are any services included within Teton that would reduce the price I currently pay? Thanks in advance, |
[2022-01-03 02:38:04] |
There is no change in these costs. But you will no longer pay CQG any fees. So your transaction fees will go down.
[2022-01-04 01:16:31] |
User837393 - Posts: 132 |
If broker is IB but using the denali services for routing and orders, do I need to open a brokerage account with Teton to take advantage of the reduced commissions and fees? If so how do I apply to open up an account? |
[2022-01-04 01:24:54] |
You would need to open an account with a broker/clearing firm that does support the Teton Order Routing Service. These are listed at step 2 here: Sierra Chart Teton Futures Order Routing: Setup Instructions You would contact them directly about opening the account. Check with them about fees. We know that Stage 5 is giving a special commission offer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-04 01:25:13
[2022-01-04 02:30:52] |
So is the Denali feed / rooting services will stop? I do not want to trade with IB data feed. |
[2022-01-04 02:44:36] |
No, that is not correct. We do not understand the reason for the question.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-04 02:44:44
[2022-01-04 02:55:02] |
I appologise I will reformulate my question. So my understanding is that there is no changes to Denali feed, but we also have the option to go with Teton, only if broker support. Is this correct? |
[2022-01-04 04:01:07] |
Yes this is a correct understanding. The Denali data feed is just a data feed. And the Teton order routing service is for order routing. These are separate from each other but are used together.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-04 04:01:20
[2023-08-24 05:37:30] |
Trade Dojo - Posts: 45 |
I have my AMP account setup with Teton and it’s tradable. When I look at the breakdown fee, it’s still $0.26 per trade with description “Clearing Teton”. What is that fee? AMP charges or Sierra charges it? |
[2023-08-24 06:08:26] |
Sierra_Chart Engineering - Posts: 17191 |
From AMP!!
[2023-08-24 06:24:51] |
Got it. Thank you very much. I compare to CQG and yes, the Teton route is lower!
