Date/Time: Thu, 28 Nov 2024 01:46:44 +0000
Replay mode
View Count: 1096
[2022-01-02 23:29:09] |
User845261 - Posts: 7 |
In replay mod I have different values in the charts. No Market depths. I cannot test historical data. Image: https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=58932 Date Time Of Last Edit: 2022-01-04 01:03:17
[2022-01-03 22:00:16] |
What exactly do you mean by "different values in the charts"? What is the exact issue you are having when running a replay? With regards to Market Depth data during a replay, refer to the following: Replaying Charts: Replaying of Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-04 01:05:47] |
The chart and Trading DOM are not synchronized with each other. For instructions to replay a Trading DOM, refer to: Replaying Charts: Replaying Trade DOM Windows If there is missing market depth data, then refer to: Replaying Charts: Replaying of Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-12 20:55:22] |
CKStealth - Posts: 3 |
Hello, I am having trouble with getting the market replay to work correctly. When I go through the setting and load to depth data, for some odd reason it does not work smoothly. I have noticed these things 1.when replaying all the charts in the chartbook, the price will be stagnant despite me loading the data, having the settings to "1-tick"and pressing play. 2. The time seems to be off no matter what date I set it to.. I made a youtube video to further explain what I mean, I hope you can help point me in the right direction. Thank you for your time. Have a great day https://youtu.be/FVKgyDAWlOc |
[2023-06-12 22:11:23] |
We can not see the settings for the replay. What kind of replay are you doing? And what is the Processing Time in Seconds that you are entering? Also, try starting with a single chart, instead of replaying multiple charts. See how replaying a single chart goes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-13 05:12:53] |
Hello, I recorded another video, hopefully this helps, I appreciate any input https://youtu.be/SxYJwYMjRQo |
[2023-06-13 15:34:45] |
We do not know why, but the TPO chart in the upper left is showing as "Paused" in the title bar. When you start the Replay and since you have it set to "Start Paused", be sure to wait 1 minute before you actually press "Play" to ensure that all the charts are reloaded and ready to start the replay. Then select "Play" and let us know if all the charts are playing properly at that time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
