Date/Time: Tue, 04 Mar 2025 19:00:51 +0000
problem to get real data in the first bar
View Count: 460
[2022-01-02 08:01:19] |
User278398 - Posts: 291 |
Hello, i am getting missing data all the time for the first bar when trading is start (9:30 N.Y). applies for live trade and historical graph. in the attach file i display real data of volume from my broker(bottom pic) the volume i got in sierra chart (top pic) is significant lower then it need to be. it need to be about 1,000,000 and in sieera chart i got 648114 ... the next bars are correct! the problem are always with the first bar. 1.how can i fix this problem? 2.if i fix this problem, will numbers bars study show me also real data for first bar? regards |
[2022-01-02 18:22:45] |
We cannot help with these differences. There are certain types of trades that are getting filtered from the US equities data from the Sierra Chart Exchange Data Feed because they are not supposed to be tracked as trades which are included in Intraday charts. However, update to the latest release. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-02 18:23:49
