Date/Time: Tue, 04 Mar 2025 19:14:52 +0000
DOM quantities
View Count: 653
[2022-01-02 02:11:46] |
User575399 - Posts: 326 |
I am using ES and im looking to have the limit order columns(dark blue and red) and the actual traded orders (inner columns) on my DOM, but the numbers seem low for ES . This pic is from RTH. I attached a pic to show my settings. Let me know thank you!
Date Time Of Last Edit: 2022-01-02 21:18:40
[2022-01-02 15:36:18] |
Up
[2022-01-02 21:17:20] |
Up
[2022-01-03 02:50:54] |
Make sure the symbol of the Trading DOM is correct based on the particular date being replayed. Use the Market Depth Historical Graph to view the available historical market depth data: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph And set it to display the last depth values: Market Depth Historical Graph: Depth Quantity Type to Display After Last Bar So if you have market depth data available, it must be correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-03 02:53:29
[2022-01-03 03:36:06] |
It’s like this during RTH as well . The quantities just seem low for ES which trades sometimes a million contracts a day
