Date/Time: Tue, 26 Nov 2024 04:44:08 +0000
Sierra Chart Login with Topsteptrader credentials
View Count: 2160
[2014-04-07 01:41:03] |
SSGill - Posts: 36 |
Hello; I have gotten started with a trial of Topsteptrader, along with which I get access to Sierra Charts. I was given this information Username: jetus Account: PTSjetusApr4 Please let me know how to log into Sierra Charts. |
[2014-04-07 16:03:20] |
Hello; I've signed up with the Topsteptrader service, and was told that I would receive a 3 month trial access with Sierra Charts. I had signed up for a month subscription with Sierra Chart, but that is expiring tomorrow. Am I able to use the 3 month access because I signed up Topsteptrader? Sorry for the confusion, this is one of the reasons, I decided to use Topsteptrader. |
[2014-04-07 17:52:23] |
We have added usage time to your account and affiliated it with Top Step Trader. You will need to restart Sierra Chart. Most likely you will be using Sierra Chart with the CTS T4 trading platform service. Therefore, refer to the set up instructions here: https://www.sierrachart.com/index.php?l=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
