Date/Time: Tue, 04 Mar 2025 21:36:10 +0000
how can i see value with comma separator
View Count: 581
[2022-01-01 19:37:56]
User278398 - Posts: 291
hello,
i'm trying to display Numbers Bars Calculated Values stuudy with comma separator.
how can i do that?
in the pic for example, delta is : -16858 ... i want to see -16,858
regards.
image1.png / V - Attached On 2022-01-01 19:35:03 UTC - Size: 91.94 KB - 147 views
[2022-01-02 18:21:58]
This is not supported.
[2022-01-03 08:25:26]
what about other study reference which can do that?
for example, can i display coma separator by "study subgraph above/below bar as text" study?
if not, maybe other study can help with my issue ?
and if yes, how can i display in those studies?
regards
[2022-01-06 15:10:15]
John - SC Support - Posts: 38369
There are no studies that do this. If you want to have a comma, then you would need to develop the study to display the value you want in the way that you want.
