Date/Time: Sat, 03 Oct 2026 22:44:53 +0000
Did I have everything I need to trade now after my purchase?
View Count: 825
[2022-01-01 18:57:38]
User989346 - Posts: 7
I applied for an AMP brokerage account and waiting for the application to go through. I purchased a 3 month package with Denali data feed. But what next? DO I need CQG for order routing? I don't know what to do from here. I just want to be able to start trading the E-Mini S&P 500 after I fund my AMP account. Is there an extra setup needed or something missing from the above? Do I need to talk to AMP or Sierra Chart?
[2022-01-03 20:59:59]
John - SC Support - Posts: 48095
AMP will have set you up with a specific Order Routing service - either CQG or Rithmic (most likely CQG). You will then need to go through the appropriate instructions in order to setup Sierra Chart to connect to your order routing service.
For CQG, follow these instructions:
CQG Trading Platform Service: Setup Instructions
For Rithmic, follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
Once you have completed the setup above, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. this will change the symbols in your charts to what is needed for the appropriate service.
You will then be able to get the real-time data from the Denali Exchange Data Feed and place your trades.
