Date/Time: Tue, 26 Nov 2024 10:43:53 +0000
not able to use Draw Volume Profile
View Count: 600
[2022-01-01 18:55:10] |
ljb2108 - Posts: 3 |
Hi, I cannot use the tool Draw Volume Profile, as soon as I use it it is static and not variable. if I place it in the chart I cannot expand it to follow the course of the chart over the volume and to spot low volume area where the Chart may change the direction. I saw it at a friend's house and he can flexibly adjust it and apply it to the chart. i have got package 11 - Advanced + Denali Data Feedand Rithmic Data Feed. best SB |
[2022-01-03 20:56:13] |
John - SC Support - Posts: 36286 |
You definitely should be able to adjust the drawn Volume by Price items. Refer to the following instructions for how to adjust a drawn VbP: Volume By Price Study: Modifying Manually Drawn Volume Profile Also, refer to the following setting which, when set to No, can help in selecting a drawn VbP: Chart Drawing Tools: Select Drawn Volume Profile by Outline Only (Global Settings >> Tool Settings >> General >> Volume Profiles) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-05 17:36:51] |
User45989 - Posts: 54 |
If you have 'Chart / Hide Chart Drawings' turned on, you will be able to draw and see the volume profile, but you won't be able to select or edit it.
