Date/Time: Tue, 04 Mar 2025 19:16:22 +0000
Account set up questions
View Count: 508
[2021-12-31 22:37:49] |
User972740 - Posts: 1 |
I need clarification on the following: 1. Can I use the same account on 2 separate computers. I will not use them simultaneously. One is for a desktop and the other is for a mobile laptop when I am travelling. 2. I was going to sign up for the Service package 5 to begin with. What more do I need to subscribe for to get real time data for CME futures and NYSE/NASDAQ stocks. 3. What is the preferred trading service for live trading? Many thanks. Azmi Zahed-Atkins Non-professional |
[2022-01-01 15:45:26] |
1. Yes. Refer to: Using Multiple Data and Trading Services at the Same Time These instructions are to install multiple copies on the same computer system but they are also applicable to different systems as well. 2. In your case you would need tto use Service Package 10. And you want to use our Denali Exchange Data Feed: Denali Exchange Data Feed Full set up instructions are on that page. This data feed will support US stock data, in January. 3. If you will be trading the CME Group or EUREX, you will want to use the Teton Order Routing Service: Sierra Chart Teton Futures Order Routing That is the absolute best service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-01 15:46:23
