Date/Time: Tue, 04 Mar 2025 19:14:46 +0000
Package 3
View Count: 501
[2021-12-31 20:48:47]
User656746 - Posts: 10
If I only would like to subscribe to the CBOT‘s Mini Package, would the package 3 for $ 26/month being sufficient?
If yes, what do I need to do and how can I change accordingly?
Kdst Rgds
Michael Zuelke
[2021-12-31 20:52:45]
John - SC Support - Posts: 38369
The CBOT is part of the Denali Exchange Data Feed, in which case you would need to be on Package 10, 11, or 12. If you do not need any of the Advanced Features of Sierra Chart or the MBO data, then Package 10 would be all you would need.
We see that you are already setup with the data feed and have the exchange active and you are on Package 10. So you should be all set at this point.
